Old 06-27-2025, 10:54 AM   #51
rbruno68
Re: Hank - 63 C10 Build
Just about got the driver side wrapped up. The corner is done and need to do some finish welding and grinding on the rocker patch. I think I am going to end up cutting a patch for where the dent is in the side of the cab. It is hard to get a hammer in there to reshape the metal. And, because I am a novice, the cramped space is making it even hard. I have plenty of cab corner left from my patch panel so I think that is what I am going to do.
After I do some maintenance things in the shop, media blasting the inside of the cab is next.
https://www.youtube.com/watch?v=9bIBcDZgt2w
Name:  Rocker Panel.jpg
Name:  Rocker Panel 2.jpg
rbruno68 is offline   Reply With Quote
Old 08-25-2025, 08:44 AM   #52
rbruno68
I finished building my air dryer needed to do some painting. As I was using some of my air tools, I was getting way to much moisture out of them. So, I knew I had to do something before painting. With suggestions from here, I built this out of an old dorm fridge. Hopefully this will fix the problem. Need to do some fine tuning and finishing, but I don't think I have any leaks. Next is having the inside, firewall, and bottom media blasted and epoxy painted. Hopefully that will happen this week.
Name:  Air Dryer 1.jpg
Name:  Air Dryer 4.jpg
Name:  Air Dryer 5.jpg
Name:  Air Dryer 3.jpg
Name:  Air Dryer 2.jpg
https://www.youtube.com/watch?v=X-wLnP-9oRU
Old 08-28-2025, 10:03 AM   #53
rbruno68
I started taping the cab for media blasting. I am having the bottom, firewall, and inside blasted. I needed to tape off around the windows and doors to try and protect my original red paint. Again at this time, I am not looking to paint the entire truck. But, I need to fix the floor in spots and would like the interior painted while doing all the work. The blaster should be here this week and after that, laying down some epoxy to seal everything up.
Old 09-02-2025, 01:55 PM   #54
rbruno68
Got some epoxy down on my firewall, bottom and inside of cab. Need a few touch ups, but once that is done, it is on to more rust repair.
Old 09-03-2025, 10:55 AM   #55
Braunschweiger
That looks very good.
Regards, Harald
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 09-04-2025, 09:16 AM   #56
rbruno68
Thanks Harold. I did my final coats yesterday on the dash. Got a run or two and some trash but nothing that won't be sanded out later. But, everything is sealed. Next is starting to replace the rust in the floor which is more than I was anticipating. The blasting opened up some new spots which I guess in the long run is a good thing.
Rob
Old 09-15-2025, 08:30 AM   #57
rbruno68
Started to repair the driver side floor. I was really worried I wouldn't be able to get the patch panel behind the already repaired outer rocker. But, I think it will be ok. I sort of discovered I probably did some of this out of order, but had to do what I had to do.
Old 09-16-2025, 01:10 PM   #58
350TacoZilla
Hey now I know who to take my truck to for the rust repair! looking good man.
350TacoZilla is offline   Reply With Quote
Old 09-16-2025, 04:16 PM   #59
rbruno68
Thanks. I hoping for a 20 feet truck. Lol. Looks good from 20 feet away.
Old 09-19-2025, 01:18 AM   #60
350TacoZilla
Yeah I always tell people 50\50. 50 feet or 50mph it looks good lol.
Old 09-19-2025, 02:08 PM   #61
88Stanger
88Stanger's Avatar
LOL agreed, 20 feet is a good ..... "awe nice ride"... lol
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 09-19-2025, 02:15 PM   #62
rbruno68
Haven't heard this one before. I might have to borrow that in conversation. Lol...
Still have some final welding and grinding, but the large driver's side patch is just about done. Next up is the toe kick and the outer rocker where the door seal will go. I think I will have some panel adjustments need to get that line straight where the toe kick meets the floor, but I guess that is all part of using replacement panels and being new at this. New video should be out this weekend.
Name:  Floor patch.jpg
Old 10-13-2025, 08:55 AM   #63
rbruno68
Got started on the toe kick area. Going to replace the top section first to establish a straight line to then adjust the floor piece that is a little out of whack. When I removed this piece, I found a little more rust in the lip of the side wall of the cab where it meats the floor. Not sure if I am going to be able to just fill the holes or if I will have to make a tiny patch. It is no more then a half inch wide. Will see the more I clean the area up.
Name:  Toe Kick 1.jpg
Name:  Toe Kick 2.jpg
Name:  Toe Kick 3.jpg
Old 10-27-2025, 11:14 AM   #64
rbruno68
Got the toe kick pieces cut and tacked in. Everything still needs to be completely welded and the welds ground, but the patches have been made and fitted. I also adjust the AMD floor patch to fit the original seam. Had to put a small pie cut in there. Now I need to move on to the curve in the door opening and the lip where the seal will sit. That will rap up the driver side floor rust.
Name:  Driver Toe Kick.jpg
Name:  Driver Toe Kick 1.jpg
Name:  Driver Toe Kick 2.jpg
Old 11-04-2025, 10:32 AM   #65
rbruno68
Finished up the driver's side floor and outer rocker. I need to finish all of my welding and grinding to wrap this up. I am sort of wishing I had removed the entire rocker and just replaced it. The lip for the door seal on the replacement panel isn't the same as the original. It is a little shorter. I don't think it will be that big of a deal. I was able to make a cut and adjust the panel where it meets the toe kick and cut a wedge to make up the difference. But, trying to adjust this lip might not be worth the effort given where it is located. Should have a complete video out tonight.
Next is the area above the windshield.
Name:  finished toe kick.jpg
Name:  finished toe kick 2.jpg
Name:  finished toe kick 3.jpg
Old 11-04-2025, 11:13 AM   #66
Shifty One
Shifty One's Avatar
Looking good!
1987 V20 farm-hand rescue
1998 C2500 lot-rot rescue
Old 11-05-2025, 10:34 AM   #67
rbruno68
Originally Posted by Shifty One View Post
Looking good!
Thanks. All those patches took me forever. I was hoping to be able to get some paint on the inside before the weather turned to chilly, but I think I missed that goal. I still have a more to fix before it is ready. Oh well, not going to worry too much about it. Gotta keep moving forward.
Old 12-01-2025, 11:18 AM   #68
rbruno68
Started to work on the area above the windshield. I took a piece from my parts truck to try and patch in the rusted area. My patch needed to go to where the mirror would be. My truck didn't have a mirror, but the parts truck did. While it is just a a couple of holes drilled in the roof area, I thought I would patch in the mirror area with the factory holes since the patch had to go that far anyway. Still working on getting the patch to fit before welding both patches in.
Old 12-01-2025, 11:53 AM   #69
66newb
66newb's Avatar
Making great progress. You had a decent roof there, ours was in much sorrier shape. Is it only the interior, or will you have some patch work on the exterior too?
66newb is offline   Reply With Quote
Old 12-01-2025, 04:09 PM   #70
rbruno68
Right now, it is only the interior that I plan to fix. There is new seam sealer or maybe just caulk in the drip rail across the top. I have not scraped that out. So, there could be an issue there. The outside above the windshield appears to be good. I don't have any holes there. I am hoping this is all I will have to do at this point.
Old 12-01-2025, 08:23 PM   #71
0ldSoul
0ldSoul's Avatar
Looks great! Thanks for the videos on YouTube, we've been tuned in watching and getting inspired along the way.
Current: Another 1963 C10 - Build in progress
Sold The '63 Restomod Build - 283/4 speed, 4.5/7 static drop, disc brakes, power steering
0ldSoul is offline   Reply With Quote
Old 12-02-2025, 11:22 AM   #72
rbruno68
Thank you for watching. I am hoping to get some more work on this part done in the next couple of days and get this video out soon.
Thanks again for watching.
Old 12-03-2025, 04:50 PM   #73
cag
Active Member
Attachment 2430374
Attachment 2430375
Attachment 2430376
Attachment 2430377
Attachment 2430378
great idea, my buddy told me 50 feet of line between compressor and water sep, buy a big one, or two, I will be adding a second, dig the fridge!
cag is offline   Reply With Quote
Old 12-04-2025, 10:29 AM   #74
rbruno68
Thanks. I have to give credit to The Astronaut who is a frequent poster. He gave me the idea and some pictures of his. It worked great for when I painted the areas that were blasted. I am also using the line that doesn't run through the extra set of filters when I use my tools and I am not getting any moisture out of the tool. And, because I had the fridge and with the cost of copper, I saved a lot of money by not buying all those lengths of tubing.
Old 12-30-2025, 12:18 PM   #75
rbruno68
Finished up the area above the windsheild. Need to do some finish work but the patches are in. The roof panel moved a bit more then I expected. Once I cut out the part to be replaced, it sort of bowed up a little. I guess all of these pieces are under some sort of tension and when a part is removed, they shift a little. I ended cutting the the patch a little short and had to fix that. Next up is a small area on the passenger side floor.
New video should be out in the next day or so.
