Old 09-04-2025, 03:19 PM   #5451
68isgreat
Re: What did you do to your truck today.The 3rd chapter
Originally Posted by Steeveedee View Post
Nice panels! I want to do this, but they aren't (supposedly) made for AC trucks. If I still had access to a brake, I'd bend my own. Just need reliefs for the AC stuff.
What ac stuff gets in the way?
68isgreat is offline   Reply With Quote
Old 09-04-2025, 06:32 PM   #5452
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
The tops of the condenser mounting brackets and the receiver/dryer. I guess I could trim the brackets and punch a hole for the receiver/dryer. I haven't gotten heavy on it since I licked the hot running issues.
~Steven
Simi Valley, CA
Old 09-04-2025, 08:16 PM   #5453
D.B
D.B's Avatar
Steeveedee, Undercover Innovations sells the panels with the AC cut out.
Darrell
1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck)
2000 S10 Xtreme (Black Magic) (My Drag Truck)
D.B is offline   Reply With Quote
Old 09-04-2025, 11:32 PM   #5454
Steeveedee
Steeveedee's Avatar
Thanks, good to know!
~Steven
Simi Valley, CA
Old 09-06-2025, 12:54 PM   #5455
ivory68
ivory68's Avatar
Cleaned up the engine bay by treating the surface rust on the master cylinder and combo valve. The Seymour Cast Blast is amazing. It dries super fast and looks great.
ivory68 is offline   Reply With Quote
Old 09-06-2025, 01:06 PM   #5456
72c20customcamper
72c20customcamper's Avatar
Painted up some of the bits for the 68
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-06-2025, 01:07 PM   #5457
72c20customcamper
Rest
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-06-2025, 01:18 PM   #5458
72c20customcamper
New radiator came in yesterday . I ended up with a Cold Case as Amazon’s had one for $215 about 200 off the list price . Description stated new condition but damage packaging. I took a chance and it’s exactly as stated box was beat up (they put the box inside another) but the radiator itself was untouched . Also got the transmission cooler went with a big one since the 2800 stall will generat a lot of heat . No picture of the radiator but the cooler is nice Derale 9500 series
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-07-2025, 10:22 AM   #5459
Chevys4life
Your engine detailing is coming together nicely!!!
Chevys4life is offline   Reply With Quote
Old 09-07-2025, 10:47 AM   #5460
D.B
D.B's Avatar
You will like the Derale transmission cooler. I just installed one in my S10 drag truck and it made a world of difference in cooling the transmission using a 4900 rpm stall converter.
Darrell
Old 09-07-2025, 12:06 PM   #5461
KQQL IT
At the body shop.
KQQL IT's Avatar
Quick wash is about it.
Old 09-07-2025, 07:34 PM   #5462
72c20customcamper
Attachment 2431309
Yank converters recommended the cooler . It’s really big in the future when I put AC on the truck it may be a little difficult to hang it all in front of the radiator. But I’ll figure something out at that time
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-07-2025, 09:36 PM   #5463
72c20customcamper
Thanks . I tend to be a little OCD when I start something .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-08-2025, 10:00 AM   #5464
Sheepdip
Sheepdip's Avatar
My A/C belt started to squeal a couple of days ago, so I ran no A/C planning to change all three this weekend. I fired Otis up Friday and heard what I thought at first to be a small engine fuel pop but had no power steering...yep A/C belt popped off and derailed the P/S belt.
So, It was belts for Otis Sunday.
Sheepdip is offline   Reply With Quote
Old 09-17-2025, 05:15 PM   #5465
72c20customcamper
Started getting ready to change out the cab mounts . Was a little surprised to see that both front bolts were welded to the floor . I carefully peeled the tar coat of from around the bolt and found this . The 68 stepside nor the 72 had that thick tar paper just the white foam insulation under the rubber mat
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-17-2025, 05:19 PM   #5466
72c20customcamper
The front nuts and the rear bolts came off with little resistance. But I was worried that I wasn’t going to be able to lift the cab high enough to remove the front bushing but it wasn’t a problem at all . And my OCD is kicking in I’m almost compelled to sand and paint the frame .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-17-2025, 08:39 PM   #5467
Jiggers72-GMC
Good work Mark, you won't be sorry that you replaced them, after I did my truck the doors close so nice again .......
Jiggers72-GMC is offline   Reply With Quote
Old 09-17-2025, 09:56 PM   #5468
72c20customcamper
I changed them on the 68 and the 72 . Makes a big difference in the ride also as long as you use the rubber and not the poly mounts
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-17-2025, 10:04 PM   #5469
Jiggers72-GMC
Agreed on the rubber mounts Mark
Old 09-18-2025, 02:31 PM   #5470
72c20customcamper
Changed out the 2447 to the new 2947 . Hayden came with this one to bring the fan further away from the radiator when you put in an oversized core. I used it because I have a long pump setup on the 72 was that way when I bought it . The clutch shaft is about 1/2 to 5/8 inch shorter so it moved the blades closer to the edge of shroud . Only problem was getting the nuts on took a lot finagling but I finally got it not much room between the hub and the studs actually had to put each one on a thread or to before moving to the next . Hub actually hit the nut and wouldn’t go on if I threaded it any more .
The fan is still in further than stock but much better now .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 09-18-2025, 06:38 PM   #5471
Orefactory4x4 swb
First drive out today
Orefactory4x4 swb is offline   Reply With Quote
Old 09-18-2025, 06:42 PM   #5472
Orefactory4x4 swb
Pics of truck
Old 09-19-2025, 01:49 AM   #5473
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Starting installing my American Autowire Headlite Relay kit i bought in 2017 or 18.. Gotta pair of the picture LED's going in soon after the wiring is done.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 09-24-2025, 02:11 PM   #5474
c30
Active Member
c30's Avatar
Today, I mounted the new license plates and called the insurance guy. Then went for my first real test beat.
c30 is offline   Reply With Quote
Old 09-25-2025, 10:05 AM   #5475
Peanut74
Moved my truck outside under its own power
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
