Old 09-25-2025, 08:33 PM   #1
Blazerowner
Blazerowner's Avatar
72 stock brake swap to Wilwood D52
has anyone swapped these in on a stock 72 Dana 44 disc brake front? I’m thinking of replacing my calipers with the D52s. Are they a direct bolt on?
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 09-28-2025, 03:45 PM   #2
Blazerowner
Re: 72 stock brake swap to Wilwood D52
Anyone?
Kirk
Old 09-30-2025, 09:49 AM   #3
hemi43
hemi43's Avatar
Just wondering why you want to do this? Anything aftermarket will be inferior quality to OEM. Unless you want the "look", I wouldn't do it.
If you want better braking, use larger OEM calipers and matching master cylinder from a late model truck.
You can also try a different pad on your existing calipers for increased braking. I've had good luck with EBC redstuff. Higher friction, low dust and good on the streets.
hemi43 is offline   Reply With Quote
Old 09-30-2025, 11:20 AM   #4
Blazerowner
I guess it’s the look for the most part. I have read others say they have better grab with these but I’m not real concerned with that. You really think Wilwood is inferior to the OEM calipers? In my experience on other cars they are high quality. Any clue if they are a direct bolt in?
Kirk
Old 09-30-2025, 12:24 PM   #5
hemi43
hemi43's Avatar
Not saying they are bad quality, just saying that OEM parts have way more engineering and better build quality because of mass production.
I've only used Dynalites in the past so can't confirm if the D52s will bolt on.
Before you use these, make sure they are compatible with your master cylinder.
Double check the piston area on the Wilwoods are the same or close to your OEM calipers. Another thing to check is the pad surface area. I don't know about the D52's, but I know the Dynalites have way too small of a pad.
You don't want to have nice looking calipers that don't perform.
My truck had drums originally and I didn't want to use aftermarket brakes because I knew I would be towing and driving it a lot. I used all late model parts to get them to fit, but have to admit I did use a Wilwood master cylinder because the bore size of the original was not correct.
It was difficult getting everything to fit inside a 15" rim, but after 30000 miles I must say they work flawlessly.
Old 09-30-2025, 09:18 PM   #6
Blazerowner
Maybe I’ll just keep the OEM. I was more or less looking for small upgrades to appearance. I’m considering 18” wheels in the future. These barely fit my 15” wheels. I had to have the weights put close to the center of the wheel so they wouldn’t drag.
Kirk
Old 10-02-2025, 08:46 AM   #7
29od1
I used Wilwood D52 Black Calipers - 1.25" Rotor Thickness, 2" dia pistons. I have 17" wheels and I don't think they'll fit 15" wheels.
29od1 is offline   Reply With Quote
Old 10-02-2025, 09:21 AM   #8
hemi43
hemi43's Avatar
Originally Posted by 29od1 View Post
Attachment 2433089
What bore diameter master cylinder did you use? Did you keep the original rear drums?Curious.
Old 10-02-2025, 10:44 AM   #9
29od1
I went with a 3/4 ton MC and also went with single piston disc calipers on the rear. I also have hydroboost instead of vacuum assist.
Old 10-02-2025, 12:04 PM   #10
hemi43
hemi43's Avatar
OK thanks.
Old 10-06-2025, 08:59 PM   #11
Blazerowner
Did they bolt right up?
Attachment 2433089
Kirk
Old 10-08-2025, 09:41 AM   #12
29od1
Yes
Old 10-13-2025, 08:17 PM   #13
Blazerowner
Nice
Kirk
