Old 03-17-2014, 01:23 AM   #1
oem4me
oem4me's Avatar
Factory wheel ID for dummies
Sorry guys, I don't have any useful info about wheels, but instead could really use a guide of sorts for spotting the various and often subtle differences between each generation of factory steel wheels. I know certain individual wheels can be worth a mint, and a seeming very close match good only for a grinder stand base. Got any links to share on the subject?
Oh, and while we're at it...
What's this wheel? 15x5 - Notice the four little bumps - for full wheelcovers ??
Old 03-17-2014, 08:21 AM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Factory wheel ID for dummies
My original 1960 GMC wheels also came with those 4 bumps. They indeed were for the 1956 passenger car wheel covers. Those and Corvette wheel covers did not use conventional gripper fingers. Instead they had a bead around the rim of the attachment flange that snapped into those bumps. Presumably the 56 Chevy wheel covers were provided as they were the last 15inch passenger car covers produced before the switch to 14" wheels.
I don't show a listing for full wheel covers in the 1960 Chevy Truck Accessories Price Schedule, but I have a few vintage photos with them installed on 60-61 trucks. Not sure if these were ever officially offered for truck applications, or if all the rims were punched with the 4 bumps in case they ended up being assembled for a Corvette application.
Here is some more info on the Jim Carter website:
http://www.oldchevytrucks.com/blog/i...-1960-hubcaps/
Your wheel may be a 1961, as I think that might be the first year Chevy eliminated the hub cap clips.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-17-2014, 08:26 AM   #3
aerotruk63
aerotruk63's Avatar
I've been watching for an old Kaysey- Hayes wheel catalog. The parts book lists the full hubcap. Never got into the wheel part numbers however.
Old 03-17-2014, 11:18 AM   #4
60-66
60-66's Avatar
I've been learning about these wheels for some time. MarkBo1 made me realize the nubs were indeed 1960, Thanks Mark. However, its my belief from buying and owning several other trucks that after 1960 if it had nubs it was an over the counter replacement rim. That has been proven in the full size Chevy world, Impalas.
At the Lambrecht auction that Blue 1960 longbed stepside had all 5 OG rims with nubs. All the other new trucks 1963 up no nubs, definitely not the only convincing argument but....
All of these rims are dated and stamped in between the beads. Roughly 1968 they started marking them on the outside by the valve stem.
One easy way to ID 15 inch rims is by the size of the valve stem. The larger stem hole was used through 1963 then the smaller one 64 and up. This does not apply to 16 inch and larger Diameters as they used the larger stem from what Ive seen through 1966 and most likely longer.
OEMs picture looks like the 1960 rim, nubs and larger valve stem but I would look for the dates to confirm... BUT, shouldn't it be a CLIP style rim and not the push on cap ?
In searching for 1966 dated rims I ran across two different manufacturers , one Kelsey Hayes and it slips my mind right now the other name but some very small differences between the two.
https://67-72chevytrucks.com/vboard/...1966+gmc+panel
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-17-2014, 07:40 PM   #5
theastronaut
theastronaut's Avatar
The '66 we bought had the four nubs on the rim, wondered what they were since my other '66 and a '65 I restored didn't have them.
theastronaut is offline   Reply With Quote
Old 03-17-2014, 08:04 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Another thought popped in my head - is that wheel riveted or spot welded together? My last original 1960 wheel was riveted.
Old 03-17-2014, 09:20 PM   #7
60-66
60-66's Avatar
Heres another version " I was told" was 1960 , not so sure anymore. Any thoughts ?
Old 03-18-2014, 01:57 AM   #8
oem4me
oem4me's Avatar
It's welded. Here's the date code info, partially obscured by the weld. ?
Old 03-18-2014, 10:13 AM   #9
60-66
60-66's Avatar
From what Im reading on Kelsey Hayes wheels, back in the 60s there were three or four different plants making wheels for Kelsey Hayes. Your wheel has "NT" stamped after the "K" for Kelsey. NT is Norris Technologies . The circle on the right is a Kelsey Hayes symbol. Im only assuming the number 1 at the end is the year. On the stamping style I posted above its stamped K 1 with a 2 underneath , this 2 is for Windsor Ontario Canada. K-1-1 is Romulus Michigan and K-1-3 will be Philadelphia Pa.
Old 03-18-2014, 11:45 AM   #10
markeb01
Senior Enthusiast
markeb01's Avatar
60-66, here are photos of my last original wheel:
Mine had a slightly different shape to the center (less backspacing), and only had 3 holes drilled in the clip humps instead of all 6. Perhaps yours is a Chevy wheel (mine was GMC), or used a different offset center being mounted in a 5.5” rim instead of a 5” width rim. Interesting yours has no wheel cover bumps in the rim although it still has clips for the hub caps.
Years ago that would have been a prime candidate for a reversed rim, as the rim has the shallow face and beautiful deep taper on the back side like the popular 5.5” & 6” rims found on many Buicks. In the early days when custom reversed rims were assembled from used parts, many Chevy and Ford passenger car centers ended up in Buick rims.
Oem4me, it’s interesting mine has a 0 at the end, and it was from a 1960. Not sure if the means yours is a 61? I don’t know when Chevy dropped the clip style hub caps.
Old 03-18-2014, 01:03 PM   #11
60-66
60-66's Avatar
[QUOTE=markeb01;6581795]
" I don’t know when Chevy dropped the clip style hub caps."
For the most part on 15 inch rims with Chevy isn't it 1960 only for clips as 1961 up was nubs ? GMC I know used the 1960 hubcap for both 1960 and 1961 and change the style of the cap in 1962 and went to nubs. Interesting that both your rims are NT wheels. My one GMC has the same exact center profile and clips as yours Mark but no outer rim nubs.
Old 03-18-2014, 07:28 PM   #12
60-66
60-66's Avatar
Heres some GMC wheel info from a 1960 dated GMC parts book and the 1960 Chevy and GMC Data books.
Old 03-18-2014, 11:26 PM   #13
MusicMan70
MusicMan70's Avatar
First off, thanks for all the detailed info and:
Special Thanks to Markeb01 for giving me that GMC wheel to help me get closer to a correct set.
Since OEM4ME mentioned steel wheel generations, I'd like to offer up this odd size wheel;
16.5 x 6.0 with 3 nubs and 6 lugs with 4" BS. Application was for a drum brake Blazer/Jimmy 4wd only.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 07-03-2025, 05:28 AM   #14
Ellensbrother
Ellensbrother's Avatar
Greetings and looking for insights to decode the markings on what I believe to be a common wheel from a 1970 C10. Below are the facts I can discern about the wheel (of which I have 5, believed to be the original ones that came on the vehicle) and a photo showing the markings on the face of the wheel. Grateful for any insights from the group.
Vehicle: 1970 Chevrolet C10/Custom
Assembly Plant: Baltimore
VIN Sequence: CE140Bxxxxxx
Engine 350 CID
Wheel Diameter: 15 inches
Rim Width: 5.5 inches
Bolt pattern: 6 lugs x 5.5-inch diameter bolt circle
Hub hole diameter: 3.5 inches
Number of Nubs to hold hub cap: 3
Number of ‘windows’: 4
Markings on the wheels: GM, H, 8, K2, 9
See attached photo of the wheel showing the markings (tire is mounted on the wheel)
Thank you.
Ellensbrother
Making the World Better One Truck at a Time
1970 C10 — Blue Lou
1977 C10 — Copper Kid; 1986 GMC Sierra 1500 — Brown Pearl; 1999 Chevy Suburban — Silver Lining; 2011 GMC Yukon XL — Black Max;
2022 Ram 1500 — Gray Matters
Ellensbrother's Albums
Ellensbrother is offline   Reply With Quote
Old 07-12-2025, 10:10 AM   #15
60-66
60-66's Avatar
There will be more markings on that wheel by the valve stem under that trim ring. The letter stamp will be on your build sheet. From the K29 Kelsey Hayes manufacturer and 9 for the year. If you remove the tire there's more stamped between the beads
Old 07-12-2025, 12:57 PM   #16
Ellensbrother
That's great information and very helpful. Thank you.
Ellensbrother
1970 C10 — Blue Lou
Old 09-27-2025, 03:51 PM   #17
Ellensbrother
Please see photos of markings near the stem. What do you make of the markings "11 AB" to the right of the stem?
Ellensbrother
1970 C10 — Blue Lou
Old 09-28-2025, 08:59 AM   #18
60-66
60-66's Avatar
Going off memory the 11 should be the month or November. The AB is what would be on the build sheet and Identifies the wheel, as to size and offset etc .Something they started doing in 1967 for all GM vehicles. Not sure if anyone has this info other than Alan Colvin who wrote the books Chevrolet By The Numbers , he was ready to do the truck books but there just isn't enough demand to make it worth it
