Old 07-17-2025, 05:14 PM   #601
raggedjim
raggedjim's Avatar
Re: Previous owner '68
Originally Posted by Roostre View Post
My day job is for an agricultural equipment manufacturer. We have several suppliers that provide parts with e-coat. We always paint the parts even if they are meant to be black on the finished product, and I was told that it is because the e-coat does not hold up well to UV exposure. So my intention is to topcoat any e-coat parts that are exposed to the elements. Example: My outer roof skin was e-coated and I painted the top of it, but did not paint the bottom of it because it is sealed within the roof.
It's easy insurance. I think I do it because I used to see rusty aftermarket fenders people had put on and not painted. Not sure if they were e-coat but I ain't taking no chances!
raggedjim is online now   Reply With Quote
Old 07-18-2025, 02:33 PM   #602
68 C10 Driver
Looks like you are doing everything I did to my cab. It was a lot of work! But cleaning the underside was very satisfying!
68 C10 Driver is offline   Reply With Quote
Old 07-18-2025, 02:34 PM   #603
68 C10 Driver
Here is how the under dash cowl area turned out.
Old 07-18-2025, 09:17 PM   #604
CG
BlahBlahBlah
Wow, looks great. Its really coming together!
Old 07-19-2025, 12:00 PM   #605
raggedjim
raggedjim's Avatar
Your's looks a good deal better than mine! Nice work. As long as mine doesn't leak I'll be happy!
Old 07-27-2025, 06:18 PM   #606
raggedjim
raggedjim's Avatar
Finally got the windshield area good enough to go ahead and flip the cab. It's close enough that I can finish it working overhead.
Old 07-27-2025, 06:26 PM   #607
raggedjim
raggedjim's Avatar
Then I started working on the firewall trying to straighten it a bit. These things have more dimples than the bearded lady but I like to get them as smooth as I can. No secret methods that I use, just a buttload of bondo and tons of sanding.
Still a long way to go before it's ready for paint. I'm thinking I'll paint the firewall and then get the cab mounted to the frame to finish the rest of the bodywork on the cab.
Do you guys do it this way or would you finish the cab while it's not on the frame?
Old 08-04-2025, 10:50 PM   #608
clay68c10
clay68c10's Avatar
Nice work man!
I would finish it off the truck unless you’re pinched for space.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 08-04-2025, 11:27 PM   #609
raggedjim
raggedjim's Avatar
Originally Posted by clay68c10 View Post
Nice work man!
Thanks! That's what I've decided to do, it makes it easier to get access to some areas.
Old 08-05-2025, 09:38 AM   #610
loudchevy
loudchevy's Avatar
I did all my bodywork and paint on the cab dolly. Not sure that is the correct way to do it, but like you mentioned it gives way more access and space to get to everything.
Scott
1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 08-05-2025, 10:51 AM   #611
Roostre
Roostre's Avatar
Looking good. My plan for my cab is to paint the bottom, inside, and back of the cab then put it back on the frame to paint the entire outside in one shot. I'm certainly not an expert, but that seems like the best way to get everything to look the same.
Roostre is offline   Reply With Quote
Old 08-05-2025, 11:00 AM   #612
raggedjim
raggedjim's Avatar
Well, I thought about doing exactly that, mostly because I know I'm like a bull in a china shop at times. I can see me painting everything separately and then scratching the Hades out of every panel trying to assemble them.
I ain't got 6 friends and a film crew to help me do this... So I reserve the right to change my mind on how it's going to go.
Old 08-05-2025, 11:15 AM   #613
Roostre
Roostre's Avatar
That is another reason I'm going to paint it all together. I typically work late at night and by myself, so scratching panels is a real concern. I'll paint the stuff I can't reach while it is together first, so it won't be seen when together.
Old 08-05-2025, 06:02 PM   #614
raggedjim
raggedjim's Avatar
I feel ya brother.
I have been working on the firewall, mostly spreading bondo and then sanding it all off. Sprayed it with a coat of primer (we all know primer hides a multitude of ills) and took a pic. At this blistering pace I should finish the work on the cab by November...
2031.
Old 08-05-2025, 08:49 PM   #615
zicc1835
zicc1835's Avatar
LMAO Im going down that same path and all my friends and film crew will help me to get there ...crazy.... I plan on putting it all together in driving mode and then disassemble paint and reassemble......no overspray on frame and its components .....im cancelling the appointment to have my head examined
GREAT PROGRESS Roger
zicc1835 is offline   Reply With Quote
Old 08-06-2025, 10:40 AM   #616
raggedjim
raggedjim's Avatar
Both ways have their own pros and cons. It's really just the doors I worry about, I THINK I can mount the bed and fenders without destroying anything.
Truth is, I have plenty of time to think about it!
Old 08-06-2025, 12:57 PM   #617
7dee2
7dee2's Avatar
I almost always build out the interior (including wiring) with the doors off (installed later without glass, lighter weight) these days. Usually have the motor running, tuned, leaks addressed, etc. Then the doors and finally the front clip last. There is plenty of room to work, and the detail will be better when finished. I also enlist help (2-man jobs) to hang all the painted sheet metal using lots of painters' tape. That's just my 2 cents.
Brett
66 El Camino: BBC, 4sd. Waiting for its turn.
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 08-06-2025, 04:21 PM   #618
raggedjim
raggedjim's Avatar
That's a good point. Having to deal with the doors while getting in and out would be a hassle and more chance to scratch and dent.
Old 10-13-2025, 09:58 AM   #619
68Gold/white
Hey,
You O.K.?
Just checking.
Jeff
68Gold/white is offline   Reply With Quote
Old 10-13-2025, 09:06 PM   #620
zicc1835
zicc1835's Avatar
Originally Posted by 68Gold/white View Post
Hey,
You O.K.?
Just checking.
Jeff
wondering TOO!
Old 10-17-2025, 10:06 PM   #621
raggedjim
raggedjim's Avatar
Thanks for checking on me guys. I've been working on a side project and haven't touched the truck in a while. I expect to be posting again in about 2 weeks if all goes well.
Old 10-21-2025, 08:55 AM   #622
HO455
HO455's Avatar
I finally finished reading your thread (Complicated by my constantly having to prove I'm a human ). It's great work you've been doing. I've picked up some good tips too but I'm wondering where do you get piano wood? I've never seen it at the home centers.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 10-21-2025, 10:23 AM   #623
raggedjim
raggedjim's Avatar
From a piano...
I've torn down a couple of pianos to re-purpose them over the years.
Old 10-21-2025, 11:14 AM   #624
68 C10 Driver
Then I started working on the firewall trying to straighten it a bit....Do you guys do it this way or would you finish the cab while it's not on the frame?
You are doing the cab the same way I am, while it is off the frame. To me it makes it easier if I have to get back under the cab like I did to install Adel clamps for power cable going back an inverter I installed. I am trying to get my frame cleaned up and back together now. Seems like you started with the frame and power train first, where I started with my cab.
Old 10-21-2025, 11:27 AM   #625
raggedjim
raggedjim's Avatar
There's a lot of similarities in our builds, we have similar taste and almost started out with the same truck! I'm glad you started with the cab, I've been using it as reference for my cab!
I only started with the frame/drivetrain because I hate bodywork! The cab I'm using shoulda been scrapped...
