Old 10-29-2025, 07:45 PM   #1
TCLARK
Heat problems.
'97 2500 454 Suburban. Heater works fine most of the time, as soon as it gets cold it just blows cold air the first time. The next time it may work fine.WTF
TCLARK is offline   Reply With Quote
Old 10-30-2025, 06:17 PM   #2
Re: Heat problems.
2 things come to mind
1,Happened to me on my 02 chevy. It was a fail open thermostat, and intermittently at first, then total. Thermostat stays open and engine never really heats up.
2. The main door controller for the heater is not closing to keep out the cold air from the heater core.
Both have happened to me.
If your engine temp gauge is getting up to its normal heat or hot range, then I would check the heater door controller (I believe its down near floor on passenger side beneath glove box area). If you engine temp is staying cooler than normal, probably thermostat.
Old 10-30-2025, 10:05 PM   #3
kaycee
kaycee's Avatar
Re: Heat problems.
Have you flushed it out lately,what a-freeze you running dexcool or has it been changed to green ?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
