Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 99-06 GMT800 Chevy and GMC Message Board > 99-06 Projects and Builds
Old 10-21-2025, 12:14 AM   #1
FinnDiesel
Duramax 2500HD '58 Panel
I realized maybe some folks on this GMT800 side of the site might be interested in my current project.
I had a very good condition 1958 GMC Task Force panel just itching to be a hotrod. It's a 3800, which is a 1-ton 3500 in todays models.
But I wanted reliability included and wanted to keep the load rating.
I searched for a number of years for a suitable donor - found the LB7 Duramax unicorn, flew out, drank some wine and drove her 1,000 kms home to Victoria BC. A one-owner mint 2001 Chev Silverado 2500HD 4x4 Duramax with the ZF6 6-speed manual trans.
FinnDiesel is offline   Reply With Quote
Old 10-21-2025, 12:40 AM   #2
FinnDiesel
Re: Duramax 2500HD '58 Panel
A couple more pics of the '58 Task Force body - it is originally blue, used by a mining company in Northwest Territories. No salt up there, so trucks are in amazing shape. I sanded and stripped the red down.
I cut the '58 floor and firewall out keeping the important parts like the hood hinge mounts in anticipation of a donor vehicle - the wait was 3 years.
Old 10-21-2025, 12:55 AM   #3
FinnDiesel
The front clip is a '55 which came with the truck. Some pics of the '01 being cut apart.
I wanted the GMT800 floor, seat bolting, dash electronics, air bags and structural integrity.
The under dash brace bar which ties the A-pillar posts together was able to stay.
Thats the '58 hubcap on the '01 steel wheel. I've not seen these wheels before, but I like them as they have a vintage look.
Old 10-21-2025, 01:16 AM   #4
FinnDiesel
We sold our house with my garage lift, so now had to come up with a rig to allow the body to be lowered a bunch of times to figure where to best cut.
I have an excavator, they are great for strength but lack finesse, so I had to build a rig to keep the body from swinging around - it actually worked well.
Those steering wheel air bags sure are a bugger to pull - there are 2 pins needing released which keep snapping back when you try the opposite side.
Old 11-05-2025, 01:35 PM   #5
connorm
connorm's Avatar
Are those GMT 400 or GMT 800 wheels? I like the look with the hub caps.
That's a nice donor vehicle to start with, you just gotta make sure the end result is as nice now lol
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
Old 11-05-2025, 10:17 PM   #6
FinnDiesel
@connorm, I kinda figured they were GMT800 spare tire wheels, but after looking at a number of 2500's, I changed my mind. They are flat enough to (almost) fit inside the '58 TF body lines, and it's cool how the vintage hubcaps fit on them.
I am trying to make the recessed 3500 dually wheels work on the truck - here are my real-world test mock-ups. Love the look.
Old 11-05-2025, 10:20 PM   #7
FinnDiesel
the wheels in question
Old 11-05-2025, 10:27 PM   #8
FinnDiesel
@connorm, I see we have similar tastes in GMC long boxes. Yours looks great with the 2500HD wheels. It's a '71 GMC 3/4 ton Sierra Grande, cousin of the Chev Longhorn. It has the 8'6" bed on a factory 1 ton frame with 3/4 ton 8 lug running gear, hence the extra 6".
Right now I'm just running it and bombing around the property once in a while. It has the wood bed, but its rotted out. Future project.
Old 11-06-2025, 07:42 PM   #9
connorm
connorm's Avatar
I spied that truck in the background. That truck has an awesome spec, the GMC Longhorn with the medium olive/dark olive has to be one of the best combos.
I actually want to take the GMT800 PY0's off and put a more period style wheel on my truck. I have actually thrown around wagon wheels, whether they are white or chrome. If only you could buy 8 lug wheels that were 16" or 17" that weren't $350 a piece.
Old 11-06-2025, 07:44 PM   #10
connorm
connorm's Avatar
I like the look of the dually rims, you could event do that all the way around. Some of the early 17" split rims that were used on railroad trucks, along with other mostly industrial applications, were high offset wheels. A similar look to the wheels mocked up in this post
Old 11-07-2025, 01:36 PM   #11
Pick121
Pick121's Avatar
Subscribed, can’t wait to see where you go with this project!
-Pickman (Mike)
1964 C10 Fleetside LWB “George”
1963 C50 “Green Machine”
[SOLD] 2019 Silverado 2500HD
2020 Silverado 3500HD
My story (Welcome Page)
Pick121 is offline   Reply With Quote
Old 11-22-2025, 12:14 PM   #12
FinnDiesel
I never thought of those railroad recessed wheels - I would assume they were all 8 luggers as well.
Old 11-22-2025, 12:38 PM   #13
FinnDiesel
Some more progress shots -
Old 11-22-2025, 12:42 PM   #14
FinnDiesel
The wheelbase is perfect. Playing with the height - trying to get the body as low as possible.
The mounting surface around the perimeter where the factory caged nuts are is already 2-1/2" below the 2500HD frame rail - and the cross beams are not installed yet
Old 11-22-2025, 01:00 PM   #15
FinnDiesel
I made up some body mounts on the ‘01 HD frame similar to stock and mounted the new 2” square tube body subframe and installed Suburban 2500 Energy Suspension bushings.
The square tube subframe is bolted to the stock task force body mount points around the perimeter with the factory caged nuts. The weight of the body bears on the square tube subframe which in turn bears on the body mounts to the frame.
Old 11-22-2025, 01:04 PM   #16
FinnDiesel
It took 2 sheets of 4’x10’ 3/4” birch plywood.
Seam is positioned so the original metal runner strips will cover.
An 8” hole was cut and a flush thru-hull threaded hatch installed for access to the fuel pump.
Old 11-22-2025, 01:09 PM   #17
FinnDiesel
The factory ’01 heater requires a fresh air intake from the cowl.
The '58 task force cowl takes air into the cab a different way down from the A-pillar sides.
Had to cut the cowl open and create a new plenum, blocked the ends and added drains on each side so the '01 heater would work properly and block the driver side off as well.
Old 11-22-2025, 01:16 PM   #18
FinnDiesel
Onto the fuel filler - the ’01 tank is on the left side vs the task force right side location.
I chopped up my parts truck ’03 Suburban and welded in its fuel door.
Old 11-22-2025, 01:19 PM   #19
FinnDiesel
on to the front -
I fabricated up a 1” tube frame to mount the '01 rad, intercooler, ac condenser in the (almost) stock locations. It took a few attempts.
I copied the ’01 front aluminum rad cradle in steel, with body mounts to the frame, so it could be welded to the 1” square tube frame. All the stock ’01 sensors were installed in the correct locations on the new cradle.
I trial fitted a dual electric fan to allow the rad etc to be located closer to the motor, but they really are not that much thinner and reasoned to keep the stock clutch fan for reliability as everything was able to move rearward about 2”.
A reasonable space was left between the rad and the clutch fan.
Old 11-22-2025, 02:12 PM   #20
FinnDiesel
The Duramax intercooler is so large, it would not fit behind the stock grille location for sure.
I figured a body mod would be easier (and much cheaper) than a custom remote intercooler set-up as some folks have done, and as well, keeping the short direct ducting, so the grille surround was cut out and moved forward 2-1/2” and welded.
It looks ok and in fact is hard to distinguish as to what’s different.
Old 11-22-2025, 02:21 PM   #21
FinnDiesel
I also incorporated the inside hood release from the ’01 !
Old 12-08-2025, 05:01 PM   #22
FinnDiesel
The dash.
I initially wanted to keep the ’58 dash, but wanted all the Duramax electronics to remain.
At the moment, I decided to fit the ’01 dash and drive it for a bit to see if I like the combination of old and newer. It certainly is a shock to see such a modern dash in the ol' girl.
The fitout was a bit complex but not overly hard.
Both outer vents have to be moved due to cutting the dash about 2-1/2” off each side.
The outer right side vent fits in a space beside the ‘01 glovebox which required the glovebox door to be shortened. Sectioned a 3" piece out and used the soldering iron to melt the end back on.
The left outer vent fits where the light switch was, which was moved to the center lower cover under the ashtray after soldering extra length to the wires. These trucks all had auto lights anyways, so the location is fine.
More to come.
Old 12-08-2025, 05:06 PM   #23
FinnDiesel
Dash top
I purchased the cheapest planishing tool from amazon.ca to (try and) build my dash top. The quality of the dies are very subpar and they do not provide matching male/female dies. The only hammer end provided is flat.
I attempted a number of times using the planishing hammer and ended up with a number of unusable messes. I went back to the tried and tested ¼” steel rod bird-cage frame and bent up multiple short pieces of sheet metal to weld up. That worked well , but a lot of work to clean-up to make smooth. The result though is great. This dash top is able to be unbolted now for access.
I modified the '01 wiper support and had to mount under the dash inside to accommodate the '58 linkage. Works great - and I get to keep the factory stalk controls.
Old 12-08-2025, 05:07 PM   #24
FinnDiesel
I hid the dash hold down bolts under the 'D' and 'R' DURAMAX letters.
Old 12-08-2025, 05:10 PM   #25
FinnDiesel
Playing around with a shifter, really want something hot rod, long and original.
One of my favourite cartoon characters, Squidwards' head is the perfect shape for the knob.
I grabbed one of the old '58 bearing caps and pounded it into shape over a trailer hitch ball in the vise and welded a long 1/2" nut into the middle. For the nose, eyes and brows, I just mig welded at low temp/hi wire speed for build up and ground smooth. Painted it up, it looks amazing! Kind of like a new Rat Fink character.
Here are the various shifter sticks I am contemplating - the left of course is the factory '01 ZF6, the next is the '58 shifter, next is '58 emergency brake handle, and the right is th '58 pto handle.
