#501 |
![]() Join Date: Aug 2004
Re: ClusterTruck; because that’s what it is
Now it was time to hang the fenders so they could get painted along with the doors and cab corners.
It’s really starting to look like something at this point!
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#502 |
Meanwhile, Dave shot the hood, cowl, and mirror arms
#503 |
And then…..
#504 |
![]() Join Date: Oct 2012
Sweet action! Congrats on the milestone
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#505 |
Starting to come together very nicely!!!
#506 |
Thanks! It’s definitely been exciting.
#507 |
Now it was time to get it assembled enough to trailer home.
And maybe take a quick zip around the shop with Dave. It’s such a cool and bright color, I’m pumped to have it together-ish.
#508 |
Panels looking great on consistency.
#509 |
Coming together extremely well, looking awesome so far
#510 |
Looks good for sure!!!
#511 |
Thanks, it's been a challenging color. We decided to paint the orange over white to give it more pop. The formula says to put it over gray. We're thinking that the white base is what's made it so sensitive. So much light reflects back thru it that you can see any variation. In the direct sun, you can definitely notice a difference depending on the angle of the panel surface. An open door looks a slight shade different than the fender it's next to because of the light angle going thru the color. Conveniently that works out to where the interior color looks fine. The distance and varying shapes of the jambs disguise it pretty well. The soft touch matte clear interior also helps.
Dave says it paints and looks like a candy, just minus the metallic solids. To turn back the clock, we would have probably chosen a gray base, but it all worked out in the end. Thanks, it'll be a good winter project to get it gapped and fitted. Spring will be color sand and polish as well as bed liner. Thanks, it has that fresh paint scent also.
#512 |
The weather here has been decent for the past few weeks so I got some trim installed.
The grille hoops went on ok, but the repop is definitely not as robust as the original. The front bumper is an old original I got from Sergio, who got it from a neighbor. It’s in ok condition and will definitely do for now. The rear is repop, and not anywhere near as thick. Just bolting in the license mount bowed it slightly. I guess that’s just how it goes.
#513 |
I have been driving it a bit. I’ve done some initial adjustments on the tune to build in a rich biased safety margin. I increased the whole VE table by 5% and everything above 3k rpm by more. So far I haven’t seen any lean conditions in my logs yet, but I haven’t gone much over 4k or 75% throttle. I will need to get my wideband in before I can get close to WOT safely.
That said, the power is definitely there and I’ve enjoyed just driving it around. It’s got about 150 miles on it now.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 01-19-2026 at 12:03 AM. |
#514 |
Each time I drive, I take a peek and check for leaks. At about 140 miles I saw some drips from the speedometer cable area.
It was the ford to GM cable drive adapter. The TKO uses one of these and I think the TKX does too. I didn’t know there was a good one and a crappy one. Seems I bought the crappy one. It doesn’t have a seal of any sort on the output shaft. Makes no sense to me and I’m surprised it didn’t leak sooner. I got the good one as a replacement and will keep an eye on it. It has 2 o-rings on the body and a seal on the output. The first 2 pics are the old, the next 2 are the new.
#515 |
I've been doing some more cruising as weather and clean road conditions permit. I've adjusted some of my VE table off of long term trims and it has gone well. The LS pcm is definitely more capable than the TBI systems. The adjustments are much closer and happen faster. I've briefly ventured into WOT under 5k and it's not gone lean on me yet.
One thing I have noticed is my factory temp gauge doesn't read high enough with the F body 3 pin sensor. I was looking thru LockDoc's build and saw his solution. I gave it a try with some jumper wires and various resistors and now my gauge is at the mid point at 200deg. https://67-72chevytrucks.com/vboard/...&postcount=570 Thanks to LockDoc for the solution. I tried different resistors in the other terminals where the factory 90ohm resistor lives, but the results weren't great. The 150ohm bridging the sensor and ground terminals looks like the fix. Unfortunately now I'll have to pull the cluster again. Oh well, it keeps me busy.
#516 |
Sounds like some great/steady/forward progress!
| Bookmarks |
| Thread Tools | |
| Display Modes | |
