Old 12-11-2025, 10:17 AM   #1
Canadian 72 C15
Clutch fitment question
I have a 72 GMC half ton with a small black 350 in it currently. Behind it is an SM 465 bull low transmission. I am swapping it out to an NV 3500 from a 2005 GMC half ton. I’m converting it to a hydraulic clutch and slave.
My question is will my pressure plate, clutch and flywheel work with the new transmission?
I have tested the clutch on the input shaft and it has the same spline as the SM 465. I have a 168 tooth flywheel which I know is compatible with an NV 3500. But I’m more so wondering about the pressure plate and the fingers whether they are any different for a hydraulic throwout bearing versus a mechanical fork which came originally on the truck.
Should I be able to just swap in the new transmission with the hydraulic slave and have everything work?
Canadian 72 C15 is offline   Reply With Quote
Old 12-18-2025, 12:35 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: Clutch fitment question
Are you using the original throwout bearing fork?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-18-2025, 01:44 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Can’t say for sure on the 3500, but I used a stock replacement 12” clutch for a 72 K20 when I converted mine to hydraulic using an 80’s aluminum truck bellhousing on my original sm 465.
Tyler
Old 12-21-2025, 01:41 PM   #4
kwmech
As long as you are using the diaphragm pressure plate and not the 3 finger, you'll be alright
