Old 09-02-2004, 04:10 PM   #1
ocbaud
Garage Queen Material
going racing tonight
i'm gonna go to the track tonight with a friend.
any bets on what i will run this time??? i'm hoping for mid/high-14's
ocbaud is offline   Reply With Quote
Old 09-02-2004, 05:56 PM   #2
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
with the motor listed in your sig I would hope you'd run at least a high 13
good luck tonight
Grande Rojo is offline   Reply With Quote
Old 09-02-2004, 06:22 PM   #3
81shavedtrk
good luck tonight
not with that upper end. But good luck post what you run. It will be a week before i go again.
81shavedtrk is offline   Reply With Quote
Old 09-02-2004, 06:36 PM   #4
Kybol
Kybol's Avatar
good luck tonight
Probably the 2.73's holdin him back
-90 454ss http://www.imagestation.com/album/?id=4289115843
-04 TRX450R
-77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD
-82 c-10 SOLD
-02 CRF450 SOLD
Kybol is offline   Reply With Quote
Old 09-02-2004, 06:40 PM   #5
Grande Rojo
paper or plastic?
could be......
Old 09-02-2004, 06:41 PM   #6
bigblock73
yeller
bigblock73's Avatar
Don't show your face around here again unless you run 14.7 or better. :p
Just for comparisons sake Eric. When Yeller was small block powered, it ran a best of 14.6 @ 92mph. This was a 350 block bored .030 over to 355. Stock 882 cast iron heads with Crane roller rockers, Edelbrock performer RPM intake, Crane cam, Holley carb, headers, shift kit & 2200 stall converter, and 4.10 gears. Basically it was a stock block with cheap bolt on upgrades done in stages. Had I had a couple more runs, it would have run even better (we were playing with timing, jets, springs, etc)
If you are concerned with going fast, your first two priorities should be tires and gears...then go from there.
bigblock73 is offline   Reply With Quote
Old 09-02-2004, 07:17 PM   #7
ocbaud
atleast i have a friend to race tonight!!!
its a civic....... but he just swapped in a new engine so he might beat me badly........
or not
Old 09-02-2004, 07:54 PM   #8
phantom dually
Project92 SWB stepside
phantom dually's Avatar
If you get bet by a CIVIC please dont tell us!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-02-2004, 10:07 PM   #9
bigblock73
yeller
bigblock73's Avatar
I bet the Civic has better gears!
Old 09-03-2004, 01:02 AM   #10
ocbaud
i killed the civic. but all those damn srt-4s killed me
best race:
rt: .451
60': 2.412
1/8: 9.872
mph: 74.97
1/4: 15.094
mph: 94.15
the best my friend ran in his civic was 16.4
Old 09-03-2004, 05:25 AM   #11
Goodys86
Goodys86's Avatar
Not bad. Your 60ft time is bad with that open rear though. Although, even with my truck that has a spool I ran a 2.4 60ft on crappy street tires and crappy track. I put my slicks on for the next run and turned 1.9 60ft (still on crappy track cond) Big difference in E.T. though!
86 C-10 SWB 2wd
-355/TH350, 3:73's (Vin# says its a V6)
Best ET: 13.0 @ 101mph (NA)
11.9 @ 108mph (100 shot)
02 Chevy 2500HD DMax (tow vehicle)
84 GMC Sierra 2500
00 Formula M6 hardtop
Goodys86 is offline   Reply With Quote
Old 09-03-2004, 08:56 AM   #12
81shavedtrk
I went 1.7 with an open carrier.
.03 RT
1.72 60 ft
7.7 660 ft
12.28 1320 ft
110 mph.
11.98 @112mph Stock suspension and little tires.
Old 09-03-2004, 11:06 AM   #13
86 Red_Bowtie
86 Red_Bowtie's Avatar
81 shavedtrk was that 12.28 @ 110 mph on the bottle or all engine?
86 Red_Bowtie is offline   Reply With Quote
Old 09-03-2004, 11:20 AM   #14
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Hmmmm.... I really figured you would have done better than that. Not a bad MPH but figured a lil more.
At least you had fun though.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 09-03-2004, 06:23 PM   #15
ocbaud
i just changed out the bushing in the dizzy a minute ago.
i'm using the blue bushing(21 degrees) with the light blue and light silver springs. all in by around 2800 rpms.
last night i was running the silver bushing(25 degrees) and the same springs. it was pinging slightly when i ran the 15.09et with the initial timing at around 14 degrees.
i set the timing back to 15 initial with the new bushing and it isnt pinging anymore and seems to run about the same.
Old 09-03-2004, 07:42 PM   #16
1972C10
1972C10's Avatar
You mean to tell me my iron headed 355 with redneck ingeniuty Runs better than that high dollar holley setup?
1972C10 is offline   Reply With Quote
Old 09-03-2004, 09:13 PM   #17
81shavedtrk
Bottle. All motor it runs low 13's at full motor tune. It runs 13.9's at nitrous tune on all motor. I was running 22 degrees total off bottle and the few times i ran it on motor was with a puny 32 degrees timming. I will make a pass some time this year at 36 degrees with my motor plugs and see if i can go 12's on motor. The 12.2 pass the bottle pressure was too high and it cut out a little. When i post the vid you will see how rich the setup was running that pass. Next friday i will go back and try for the 11's. But we can only see. Then time for boosted motor
Old 09-03-2004, 10:51 PM   #18
low 84
low 84's Avatar
pretty good man. if you swap to 3.73's from 2.73's it will feel like your spraying 100 shot compared to what it was before. should put you low 14's.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 09-04-2004, 12:11 AM   #19
81shavedtrk
Or just go ahead and spray a 100 shot
Old 09-04-2004, 02:21 AM   #20
ocbaud
i'm shooting for 13's.
i know my tires are gonna be a huge part in that though
Old 09-04-2004, 02:26 AM   #21
1972C10
1972C10's Avatar
Get some modifed Tires They run well and hook decent on a pair of 8" wheels Ive got a pair mounted up with screws and tubes on some old wagon wheels painted black They get soft if you get a fresh pair
Old 09-04-2004, 04:36 AM   #22
TIMSPEED
TIMSPEED's Avatar
Tires only play a big factor in ET's...if I were you, I'd shoot for 100mph trap speed.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-04-2004, 08:49 AM   #23
bigblock73
yeller
bigblock73's Avatar
Trap speed won't win you a race, low ET's will! The boy needs GEARS. The only place I would be "racing" with 2.73's is Bonneville!
Old 09-04-2004, 09:55 AM   #24
screwballl
Tonawanda 454
screwballl's Avatar
as most of my racing is done on the street versus all these crappy little rice burners and whatever else comes along, theres no clocks or stopwatches from a stoplight, just gas and go.
I had to take down my rearview mirror because im getting sick of seeing so many so far behind me. :LOL:
(actually the heat made it fall off lol)
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 09-04-2004, 10:23 AM   #25
81shavedtrk
Its all in the 60 ft. If you can't get to the 60 fast you are screwed in the end. I have seen 11 sec all motor cars run low 11's with a 109 mph. and 12 sec cars with 100 mph trap speeds. 60 ft is where its at.
