Old 01-25-2026, 10:55 PM   #1
steves1967
steves1967's Avatar
C-20 front wheel rubbing
I added 20" Detroit steel wheels to my 71 c-20. I have as much offset as DS can build into the wheels but the front wheels still rub the inside lip of the fender when the suspension compresses. Ive looked at other trucks that seem to have no problem tucking the wheel into the wheel well. Could this be a wheel issue, and disk brake issue, or maybe it's the 2" dropped spindle issue? I know on other cars adding disk brakes pushes the wheel out a bit... any ideas? Id like to lower the front some more.
'71 Chevy 3/4 Ton Longbed
'22 Chevy Tahoe RST
'67 Firebird- 8 sec street car
'24 GMC CC 4x4 Duramax Dually
steves1967 is offline   Reply With Quote
Old 01-26-2026, 11:20 AM   #2
weq92f
weq92f's Avatar
Re: C-20 front wheel rubbing
Seems I've read on this site about some spindles increasing the front track....which could/would reduce clearance. The options you have include modifying the fender slightly (rolling), dialing in additional negative camber or both. Not sure if our fenders are good candidates for rolling though
https://low-offset.com/workshop/what...-roll-fenders/
I suppose you could also attempt fitting shorter/narrower tires?
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-27-2026, 06:30 PM   #3
SCOTI
SCOTI's Avatar
Most drop spindles do push the track width out (usual number is .375" per side).
What size are the wheels (width & back-spacing)?
What size are the tires?
What are the drop specs?
What are the alignment specs?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-28-2026, 01:07 AM   #4
Accelo
Accelo's Avatar
With the max amount of wheel offset already built in consider a wheel spacer of maybe 1/2". Might be all that is needed. However, you really didn't specify if you have room to go out before hitting.
Accelo is offline   Reply With Quote
Old 01-28-2026, 01:24 AM   #5
Richard
Might not be seeing this right? He is already hitting the fender lip. A spacer would make it worse. Rolling the lip or a narrower shorter tire as mentioned are the options I see. Well, there is also a different set of wheels as well. Also raising the front and lowering bump stops is another option.
Richard
Old 01-28-2026, 02:59 AM   #6
dagnabbitt
dagnabbitt's Avatar
I assume he means the inner fender. Some tubbed wheels wells can keep that great looking stance as it is.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 01-28-2026, 01:20 PM   #7
SCOTI
SCOTI's Avatar
It could be either depending on the specifics since both are within the realm of making contact.
That being said, I'd bet the wheel needs a different backspace/offset to tuck it in (knowing the Detroit Steel wheel dimension limitations). Need more info on the set-up first.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-28-2026, 07:57 PM   #8
connorm
connorm's Avatar
Being a '71 C20, you will have the disk brake front end. This is 1.5" wider, 3/4" wider per side. It's possible some of the other trucks that you saw had these wheels on the narrower drum brake front end and could tuck the wheels.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
Old 01-29-2026, 04:01 AM   #9
Richard
Yes maybe wrong. I try to stick to what is said in the inquiry which was "rub the inside lip of the fender" Not inner fender, not wheel well or wheel tubs. Also contact with fender is more common to boot. Hope the OP clarifies to eliminate any questions.
Richard
Old 01-29-2026, 10:29 PM   #10
steves1967
steves1967's Avatar
Yeah its rubbing the inside of the fender lip. It's a 20 x 8 wheel with 4.5" of back spacing. Detroit Steel says the max back spacing they can do is 4.75". I'd hate to drop $1k just to "see" if the extra 1/4" fixes my problem. The truck is lowered 3" in front. 2" from drop spindles and I cut an inch off the springs. Seems like custom tube a-arms would be the way to go to guarantee everything fits.
'22 Chevy Tahoe RST
Old 01-30-2026, 11:09 AM   #11
SCOTI
SCOTI's Avatar
You'll prob want more than .250" change. Common front BS is 5 - 5.25" to keep the tire away from the fender lip.
Narrowed front arms would help.
More NEG Camber might help (you didn't list the alignment specs).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
