Old 02-15-2026, 11:41 PM   #1
Luke87gt
Luke87gt's Avatar
Advice on welding small floor patch (SF Bay Area)
Hi guys, my 69 has solid floors.
However, right over the transmission (just in front of the bench), the floor has 3” x 3” hole that needs to be patched.
I’m looking for someone local that has experience welding sheet metal and can make a house call.
The hole is very accessible with the bench out (I’ll have it out).
Does anyone have a recommendation that I can pursue? Thank you!
1969 C10 Shortbed
Luke87gt is offline   Reply With Quote
Old 02-16-2026, 11:31 AM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: Advice on welding small floor patch (SF Bay Area)
over the hill from you in brentwood, try Kirk welding. they have a mobile truck and they can weld anything BUT they aint cheap. (925) 634-4250. hope this helps you.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 02-16-2026, 11:16 PM   #3
Hidesertchevy
Wish I was closer I would do it for you.
Hidesertchevy is offline   Reply With Quote
Old 02-17-2026, 12:44 PM   #4
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Wire brush the snot out of the area on both sides and bond in a patch of metal with J-B Weld. Underneath, you can spot in some paint and maybe some undercoating. You'll have carpet or the standard floor mat covering it, right?
~Steven
Simi Valley, CA
Old 02-17-2026, 02:07 PM   #5
MySons68C20
MySons68C20's Avatar
I was thinking the body epoxy stuff they use on the newer rigs.....same idea
as Steeveedee
MySons68C20 is offline   Reply With Quote
Old 02-17-2026, 03:08 PM   #6
68 C10 Driver
as Steeveedee
I had the same thought, use body panel adhesive, much cheaper than paying someone to come weld it. The metal will rip before that adhesive gives. SEM makes a great product, you can get the specialized caulk gun on Amazon for $40.
https://www.amazon.com/Traktronix-Co.../dp/B0DMWX1QX2
This gun also works with their seam sealer if you need to redo the rain gutters or reseal the seams inside the cab.
68 C10 Driver is offline   Reply With Quote
Old 02-17-2026, 05:22 PM   #7
Rust_never_sleeps
Rust_never_sleeps's Avatar
License plate and self-tapping screws? ;-)
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 02-17-2026, 05:23 PM   #8
LS short box
In regards to panel bonding.
Every body shop has a panel bonding gun. Typically battery powered. The panel bonding gun holds two tubes. The material it mixed as it is pushed thru the nozzle.
I would contact a local body shop and maybe for a few bucks you could have one of their techs come over to your shop and apply the panel bond. Could save you some cash?
After application it needs to be clamped really well and set overnight?
Old 02-17-2026, 07:34 PM   #9
Rust_never_sleeps
$80 for a stick/tig machine(lift tig, ftr)
https://www.arccaptain.com/products/...l-stick-welder
Old 02-17-2026, 07:51 PM   #10
'68OrangeSunshine
'68OrangeSunshine's Avatar
Might be cheaper to source a new Tunnel Hump and bolt that in. Was your truck a Manual and you're switching to Automatic transmission?
Old 02-17-2026, 07:54 PM   #11
Luke87gt
Luke87gt's Avatar
3 OTT currently
Future might get a TKX but not anytime soon
1969 C10 Shortbed
Old 02-17-2026, 08:19 PM   #12
'68OrangeSunshine
Originally Posted by Luke87gt View Post
3 OTT currently
OK. Sounded like a shift stick hole. With a Saginaw 3-speed you shouldn't have one. Sorry for intruding.
Old 02-17-2026, 09:10 PM   #13
mr48chev
mr48chev's Avatar
I'd go with cutting a patch out of some scrap sheet metal the same gauge and cleaning the area around the hole and on the back side of the patch and get the JB weld adhesive that I thought best did the job.
For welding it quite often there are local bodymen who do side jobs but most will hit you for a minimum fee of a couple of hours pay for something that small.
My ongoing truck projects:
Old 02-17-2026, 09:37 PM   #14
'68OrangeSunshine
I have a '72 K/5 Tub, I bought as parts for $200 some 20 years ago. The POs were surfers -- judging by the surf shop decals on the windshield.
Their solution was to flatten Pepsi cans and JB Weld them to the rust holes in the deck. Still there.
Old 02-18-2026, 03:15 AM   #15
Rust_never_sleeps
I wondered the same thing. Not a lot of reasons for a hole in the floor
Old 02-18-2026, 10:32 AM   #16
raggedjim
raggedjim's Avatar
I may have worked on that truck...
raggedjim is offline   Reply With Quote
Old 02-18-2026, 10:50 AM   #17
my67c20
Check with local high school or colleges. The hump unbolts so no need to pay house call rates.
my67c20 is offline   Reply With Quote
Old 02-18-2026, 03:17 PM   #18
Rust_never_sleeps
The guy at Minute Muffler in Dublin welded a cast-iron manifold for me years ago, but I doubt he'd make a house call. He might know someone, or maybe just roll over there when she's making smoke and noise again
Old 02-18-2026, 03:32 PM   #19
68panelman
68panelman's Avatar
Might be an opportunity to learn welding. Get a $89 HF mig, $30 helmet, a sheet of steel, cut an fit, then zap away!
68panelman is offline   Reply With Quote
Old 02-18-2026, 03:51 PM   #20
Luke87gt
Luke87gt's Avatar
Great idea, I’ll check with him. He’s actually installed an exhaust on another car I own, did a good job.
I actually have a welding certificate from 15yrs ago but don’t have the equipment and not confident with sheet metal. Since it’s this one small job, prefer to leave it to the pros.
And since it’s a small spot, maybe a JB weld patch wouldn’t be a terrible idea if the house call is too expensive. When I get the through-the-floor manual trans in the future, I’ll probably cut right around that spot anyway.
You guys are all helpful, thank you for the ideas.
1969 C10 Shortbed
Old 02-18-2026, 06:45 PM   #21
JohnC67
I live in your area. You can come to my house and use my welder if you want. It might be a challenge getting our schedules to mesh but if you aren’t in a hurry….
I’m not super awesome but welded a lot on my Chevelle and for a floor pan, it’s not like it’s got to be pretty.
Have a picture of the hole?
JohnC67 is offline   Reply With Quote
Old 02-18-2026, 07:10 PM   #22
'68OrangeSunshine
Nothing is impossible in this Small World/Vast Universe of vintage Chevy Trucks...
Don't know much about that '72 Blazer's backstory. I bought it in Lake Havasu, AZ, in 2002 for $200 as parts. Just a tub, with seats, doors, roll bar, front and rear axles -- and not much else. PO had welded a Kangaroo bar to the front frame ends. Making me think it was used in the Tules as a big go cart, the 'Roo bar to knock down the big cattails as it blew thru the swamps along the lower Colorado River.
Flint plant in the VIN code.
Baby Blue.
Right now it's my ''Spare'' for my '71 Jimmy. But one day I want it to run with a 292 L6, SM465/T221 with a ragtop, as a desert cruiser.
