Old 02-22-2026, 11:25 PM   #351
Roostre
Roostre's Avatar
Re: Roostre's 1967 C20
Originally Posted by '68OrangeSunshine View Post
Check the rubber capstan roller inside each cart[ridge].
My Dad left me a '73 Lincoln Continental with factory Philco 8-Track. Worked OK, until I tried a cart from a used book store. The roller had gone gummy and smeared goop all inside my player. Effectively killed it, as I had no way of getting the unit out of the highly vinylized dash without breaking stuff.
Thanks for the tip! The Charlie Rich cart didn't have rubber rollers, only one plastic one. Here's a picture of it and the doner cassette bluetooth adapter as I was gutting them. I'll have to check Merle Haggard and see if he has rubber rollers.
Roostre is offline   Reply With Quote
Old 02-23-2026, 12:12 AM   #352
'68OrangeSunshine
'68OrangeSunshine's Avatar
I was a Broadcasting major in junior college in LA in the Late '60s/Early '70s. [LACC] Studying to be a DJ or something like one.
To distinguish between different media sources, we called the little reel-to-reel cassettes, ''Cassettes'' and 8-Track recording units, ''Carts'' short for cartridges. ''Tape'' meant 1/4'' reel to reel. ''Record'' was vinyl disc.
Long before CDs.
Now I work in technical Theatre as a Carpenter. I used to be a lighting guy [''Electrician''] but that stuff got way too complicated, so they put me in Carps and I butcher wood. 39 years in the stagehands union.
Old 02-23-2026, 12:13 PM   #353
raggedjim
raggedjim's Avatar
If you have any questions on the ashtray hit me up. I know I make it look easy but there are some things I did that I didn't cover well.
So on the 8-track, did you remove the tape and other internal parts?
Here's a cassette player I repaired recently.
raggedjim is offline   Reply With Quote
Old 02-23-2026, 12:31 PM   #354
Roostre
Roostre's Avatar
Originally Posted by 68OrangeSunshine;9423935]I was a Broadcasting major in junior college in LA in the Late '60s/Early '70s. [LACC] Studying to be a DJ or something like one.
Long before CDs.
Does that mean you build scenery and stuff like that? I always thought that would be a great job.
Old 02-23-2026, 12:37 PM   #355
Roostre
Roostre's Avatar
When I get to it, I'm sure I will. Thanks!
Yes, I gutted the interior of the 8-track with the exception of the roller. I could probably have taken that out as well, but thought having it in place was better than the hole in the 8-track. I had to cut some of the 8-track casing to run wires and the pickup, along with holes in the back of it for the on/off switch, the LED, and the charging port. I also had to add longer wires to the pickup.
Initially, I was thinking about using the voltage that 8-track players use for determining the end of the tape to run the bluetooth so I didn't have to worry about charging the internal battery. I decided to just go with an internal battery to not add another complication to it for my first go around. I may make another one in the future.
Old 02-23-2026, 12:41 PM   #356
raggedjim
raggedjim's Avatar
Nice, thanks!
Old 02-23-2026, 03:23 PM   #357
Roostre
Roostre's Avatar
I ran out over lunch today and installed my genuine Wall Drug blanket turned seat cover. I needed to fix my mom's walking foot for her sewing machine so she could sew patches on it to keep it from unravelling at the slits I cut to get the new seatbelts through. My previous pictures of the interior either did not have the seatbelts installed or they were under the blanket. One step closer to spring time cruising.
Old 02-23-2026, 04:49 PM   #358
'68OrangeSunshine
Sometimes I build it. Most often -- like for a road show -- it gets pulled off the trucks and we assemble it as the Local Crew, and then operate it during the show if required. It's fun. Sometimes it's too much like work.
Old 02-24-2026, 11:23 AM   #359
Roostre
Roostre's Avatar
Yep, that does sound like a cool job.
Old 03-08-2026, 06:09 PM   #360
Roostre
Roostre's Avatar
Went out today thinking I would do a simple oil change on my truck. At some point in its history, someone converted it from a canister style to the newer style oil filter. That oil filter was probably on there for around 10 years. The picture shows how it came off. I ended up dropping the exhaust to get enough room to work on it. On the plus side, I found out I needed a new collector gasket. I was going to replace my lower radiator hose, but the oil change took much longer than I was planning.
Old 03-08-2026, 08:05 PM   #361
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I'm laughing with you! Been there and done that.
~Steven
Simi Valley, CA
Old 03-08-2026, 08:09 PM   #362
zicc1835
zicc1835's Avatar
ouch.....
zicc1835 is offline   Reply With Quote
Old 03-08-2026, 08:50 PM   #363
Roostre
Roostre's Avatar
It's pretty rare for me to lose my sense of humor on a task. This became comical after 4 different styles of filter wrench didn't touch it and I had to remove the exhaust to resort to a hammer and chisel. There was oil everywhere, but at least I know my tools won't rust. This was without a doubt the worst filter I've ever had stuck. Thankfully there was room to get a hammer and chisel in there. Neither my wife's nor my daily driver would have had the space around the filter to do that.
Old 03-21-2026, 10:44 PM   #364
Roostre
Roostre's Avatar
We had a beautiful day today, so I spent some time on the truck. While mounting my new tires, I found a leaking rear wheel seal so I tore that apart. The bearings were pretty rough, so I ordered new bearings, races and a seal. They should be in next week sometime. So while I'm waiting, I decided to replace my lower radiator hose. I ended up shaving a little off of the bent up area of my 67 frame to clear the hose. I suspect that the aftermarket aluminum radiator that I'm running was causing the interference. It's all good now, and should be ready for some shakedown cruises once the bearings and seal come in. Unfortunately, no good pictures, but I may take some while doing the wheel bearings.
Old 03-21-2026, 11:20 PM   #365
'68OrangeSunshine
One small move at a time, Man.
Old 03-22-2026, 01:18 PM   #366
Roostre
Roostre's Avatar
Yep, all of the big exciting stuff is done, now I'm onto the small things that make it a reliable driver.
Old 03-22-2026, 07:30 PM   #367
'68OrangeSunshine
I gotta replace and repair the Speedo in my '68 C/10 Stepside. Won't go above 35 MPH indicated, regardless of actual speed. Using GPS now, but the small numbers are hard to see in afternoon glare. My Magellen is sitting on top of the pulled-out ashtray, top taped to the Radio Delete Plate, so it's an off-center sight picture too.
I thought I had an extra Dash w/gauges, but I only found the Bezel and no gauges. So, I will have to pull the Speedo out of my dormant '67 K/10 Suburban project, install that temporarily in the Stepside -- so I still have a running back-up rig -- and send on the '68's Speedo to PJ Moreland, who kindly offered to recalibrate it for me.
Also the Battery went flat. Two years old, not enough regular use.
Old 03-22-2026, 09:30 PM   #368
Roostre
Roostre's Avatar
Fun. When I saw my bearings were toast, I actually thought about pulling the hub and bearings out of my trailer that happens to have a spare rear end under it to get the truck going again. I came to my senses when I realized that I would likely have to wait for a new seal anyway, and the weather was supposed to turn cold again. I've waited 5 years, what's another week? And likely the trailer bearings aren't any better than the truck ones.
My speedometer is also off. It reads about 10mph fast. Small rear tires, but at least I can use it to estimate how fast I'm going. It would get annoying using GPS all the time.
Old 03-23-2026, 01:27 AM   #369
'68OrangeSunshine
When the 3.73 12-Bolt Eaton Posi Rear Diff on my '71 Jimmy blew out in 2010, I was broke, so my cheapest option was to cannibalize the Read end off my '67 K/10 Suburban -- which had a rebuilt 3.73 12-Bolt Rear with Auburn Posi.
We were able to shoehorn the '67 Rear under the '71 Jimmy K/1500, but the wider 1971 rear end would not fit on the '67 K/10.
But I learned a lot about differentials during that mid '90s rebuild. PO has already used Bearing Savers. OEM axles were worn past spec. At that time, the UAW was on strike at te GM Eaton plant, and the local Chevy dealers were hoarding axles. I was able to get six lug GM Spec axles custom made by Moser for cheaper than the GM parts. When they came, the base plate that the wheel lugs are bored into had a smaller diameter. I phoned Moser about that. Their Tech guy said their axles were lifetime warrantied and the smaller diameter didn't matter.
So that rear diff has been under the '71 GMC for 15 years with no problem.
Old 03-29-2026, 08:59 PM   #370
Roostre
Roostre's Avatar
My new bearings and seal showed up, so I finished my rear wheel seal job today. This Eaton rear was a little different than other floating rears that I've done. It uses regular tapered roller bearings like I expected, but the outer race is installed from the inboard side of the hub. So this means that instead of installing the race and then dropping the bearing in, the bearing needs to be in the hub and the race is installed behind it. To remove this bearing and race, a punch can be used to punch it out through the axle mounting holes. You can see the new race shining in one of my pictures. There is also a large snap ring in the center of the hub to keep the race from walking inboard. It actually went pretty smooth. I put the race and bearing in the freezer while I cleaned everything up. Then I made a race driver with some 3.5 inch OD tube with 3/16 inch wall. I welded a plate on the back of it and drilled a hole for my race installer handle. Worked great to get the race seated. I seated the inner race just like any taper bearing race. Then I installed the seal. I lubed everything up with some 80w90 gear lube, and reinstalled everything. I didn't have a socket to remove the wheel nuts, but a chisel and hammer works well. I replaced the rear differential lube with fresh 80w90 while I was there. There are some pictures of the installation below along with a picture of my race driver.
After that, I decided to do a test drive with my son. We got about a mile down the road and I started smelling coolant and my temp gauge pegged. We turned around and limped home. Once there, I found out I'm an idiot. I checked the coolant level and forgot to put the radiator cap back on. It blew all of it's coolant on the side of the road. Hopefully it wasn't hot long enough to do any lasting damage. I'll get more antifreeze tomorrow and see. I also took this opportunity to cut my fan shroud so the fan actually sticks out of the back of it about an inch like it's supposed to. It is not an original fan shroud, I suspect it's from a square body. It is also pretty cracked up and patched back together with aluminum and pop rivets, so for those two reasons I do not feel bad about cutting it up to make it work better. Unfortunately no pictures of that, I'm falling back into my old habit of working and not taking pictures.
Old 03-30-2026, 03:08 AM   #371
'68OrangeSunshine
Dude, you possess mad skills. I'm in awe.
I know what you mean about just doing it, and forgetting the pix.
I usually listen to old time radio shows on earplugs when I'm working on a truck.
Radio ''Gunsmoke'' and ''Dragnet'' are faves. But if I have the 'Radio' on youtube on my cellphone,
then I have to pause the show to shoot a pic.
Old 03-30-2026, 12:08 PM   #372
Roostre
Roostre's Avatar
Thank you, I'm much more comfortable with the mechanical work rather than the body and paint work. The spring after I turned 16, I ran out of gas money. My dad said it was time for me to get a job, so I wandered into a small family owned trucking company. They hired me to wash trucks, but quickly realized that wasn't enough to keep me occupied, so I moved on to changing tires. No tire machine, doing it with 2 spoons and an inflation cage. I ended up working there through high school and putting myself through college in that shop. I became very good friends with the mechanic there (which continues to this day) and he taught me everything about keeping their trucks on the road, along with a fleet of local farmer's trucks. He taught me that if something is put together, it can be taken apart, and if I can take it apart, I can fix it and put it back together.
I've also started using earbuds in my shop. It's a lot easier than putting earplugs in when things get loud, I can still hear the radio over the air compressor or furnace, and I can decide if I want to take a call if someone calls me while I'm working.
I didn't take a lot of pictures of the wheel bearings because it's a really greasy process and I didn't want to get the old phone greasy. I like to take what I can to share on here because it helps me remember what I've done to my truck. Also, I hope that I can help others and give back to this community that has helped me out a lot.
