#101 |
![]() Join Date: Jan 2007
Re: 72 Cheyenne Super
I wonder how those wheels would look with year correct stainless hub caps?? I went that direction with my 68 even though it came with factory covers.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
#102 |
![]() Join Date: Apr 2005
Thanks sir.
I think the wheels would look better with some poverty caps or the year correct caps like you posted. Somewhat limited given they need to be 11.5" if I remember correctly. Something shiny to break it up some |
#103 |
Well I got it running again. Runs smooth with new timing set. Transmission wouldn't turn the tires but it just needed some more oil so all good there.
Couple little issues. The water pump is seeping out of the back. I sacrificed some wrenches, ground them down to tighten the 6 bolts. It slowed it down but doesn't appear to have stopped. Ill double check again tomorrow but it will probably need a new back gasket. Man, I don't want to pull it all apart, chip bolt paint etc. So frustrating. Also when I had the rad re-cored I went with a three core. Not knowing there was a difference in shrouds. it doesn't fit like it did before. I used some small hose for spacers for the time being. I guess there were a lot of things done to not have any problems. |
#104 |
Wheeled it outside to rinse off the year's worth of garage dust and drove it for its maiden test run. The only issue is a loose connection or ground for the voltage regulator.
There is still some work to do, bumper, headlights, antenna etc but it's winding down. Just in time for winter. The stance is just about right for me as I didn't want it too low. I'm considering Sniper Qjet fuel injection. They say to get it running first so I went that route vs putting it in as part of the project. |
#105 |
![]() Join Date: Jun 2019
Very nice truck
#106 |
Sacrilege
To make the truck more user friendly and to not load up on fuel on slow drives, I took the plunge and installed a Sniper Qjet and upgraded the 37 amp alternator to an internally regulated unit. Nothing was permanently altered (which for whatever reason I still find important).
I was able to tuck the fitech (50006 mini) up under the batter to keep it hidden. I used an angled fitting for the pressure gauge which has the side benefit of making the gauge readable looking between the batter and radiator support. |
#107 |
Running the Sniper with the original points distributor left a lot of room for improvement. It was tough to get the fuel tables dialed in because of the inconsistency with the points.
I took the plunge and installed the Hyperspark. The improvement has been better than the difference between the carb and fuel injection. The drivability has made the Sniper and Hyperspark worth it. Caveat, I have been unable to join the Holley forums. I go through the registration process but I never get approved by a moderator. I am wondering if anyone else has had issues joining Holley's forum. My presence here indicates that I know how join a forum : ).
The lid is stuck on my jar of anti seize |
#108 |
![]() Join Date: Dec 2017
72 Cheyennes had them, or mine did. I am not bothering replacing mine as they are not really noticeable, and I am not going for a 100 percent correct restore.
#109 |
![]() Join Date: Dec 2020
very nice truck and great attention to detail,the way it should be,for me anyway.she's a beauty.
#110 |
![]() Join Date: Feb 2003
love the truck, color, and most of all keeping it mostly original. awesome job
1971 K5 CST Blazer 1965 C10 Short bed all original 1949 gmc 100 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#111 |
I looked for a couple of years for an NOS or great condition inner fender for the pass side. I ended up ordering a repo and now I am deciding to use the whole thing or go for a patch. The underside brackets are shaped somewhat differently so leaning towards a patch using the original reinforcement.
#112 |
![]() Join Date: Apr 2008
Nice work- going to be a fun truck next summer
71 C10 72 K20 72 K10 Super Kirk |
#113 |
I opted for the patch to keep as much original as I can. Lots of welding and grinding to go but the test fit showed I welded in the right spot.
#114 |
When hitting a bump at speed, the rear end would get a little squirrely, almost like rear steering.
I don't know how the should of the trailing arm bushings being cracked affects handling, but it can't hurt to replace the likely original bushings. I am also running the original shocks on the rear but I will replace those as well.
#115 |
nice work on the inner fender
i would ve done the same esp patching it like that cant beat the original stamping its also hard sourcing out nos parts also depends on the item some are just scarce or they want to much coin for it
dont want to hear excuses, i want to hear solution(s) |
#116 |
Thank you. I put off fixing it as long as I could. Issue is, both sides are visible which can make it a challenge to have both sides looking like there is no patch. Undercoating will help.
While I had the trailing arms out for bushing replacement, I decided to clean them up and stitch weld before painting.
#117 |
I don't know how well this is going to work out but it is time to get in and repair the A pillar. I want to make sure I get everything lined up the way it is now so I built a removable jig to make sure the rocker ends up in the same place.
#118 |
![]() Join Date: Jun 2002
Great idea, I have had a couple of rockers I fought with to get them to fit and that would have helped. I think most of my rocker problems were caused by the inner rocker/floor panels not being stamped correctly.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#119 |
I am hoping to avoid door fitment issues by creating several jig points so I made another for the rear of the inner rocker. Ill have more at the front which give me up and down along with in and out points of reference.
Certainly someone has done this before so Id be interested in how it worked out or if I am wasting my time and should just put the door on and off numerous times.
#120 |
I was never smart enough to do that! I'm a door on/door off repeated endlessly until it worked kinda guy! It's gotta be better than my process.
#121 |
![]() Join Date: Aug 2004
That's a great idea. I used measurements off reference marks and it turned out ok, but I like your idea better.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
#122 |
Im glad I made the jig stops. I began fitting the inner rocker and was able to tell it was about 3/16" to 1/4" too high at the step for the outer rocker. I might not have been able to notice otherwise. So, I made a pie cut to lower it at the rear. It fits fine at the front. Of course I now have more welding to do.
#123 | |
#124 |
Thank you.
I got the inner fitting well and about welded in with the B pillar tacked. I am disappointed on how the A pillar fit. Using the jig to locate the fender bolt hole and the cab support bolts to locate the patch, the line up was pretty bad. I got the face moved over and now I will slice the rear near the bolts and get all sides lined up.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
