Old 02-15-2026, 02:46 PM   #1
IT Cowboy
IT Cowboy's Avatar
Anyone ever have valve covers powder coated?
I am thinking I would like to have my valve covers powder coated orange - but they are aluminum. I think that can be done but I dont know if that is too much heat and would mess them up.
I would get stock steel orange ones but everyone says those are more prone to warping and leaking.
1972 C10 Custom Deluxe Highlander 402
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old 02-15-2026, 05:15 PM   #2
Sheepdip
Sheepdip's Avatar
Re: Anyone ever have valve covers powder coated?
Factory tin valve covers would be a no-go for me, Aluminum I believe goes thru an extra step or two to powder coat but can be coated.
Sheepdip is offline   Reply With Quote
Old 02-15-2026, 05:31 PM   #3
LS short box
Powder coat loves a sand blasted surface. I would check with the powder shop you like and see what high temp orange they can supply without costing an arm and leg for special powder.
Old 02-15-2026, 08:25 PM   #4
IT Cowboy
IT Cowboy's Avatar
I had a set of polished Jeep wheels clear powder coated and they came out great and never needed polished again.
Old 02-16-2026, 12:31 AM   #5
jocko
jocko's Avatar
one thing to consider is the powder coat doesn't always necessarily match the engine paint exactly. lotsa folks poo poo the original valve covers because they are prone to oil leaks. I'd submit we humans are prone to way over-tightening the valve cover bolts (Lord knows I have at times). Anyway, just wanted to mention the potential color matching issue - could be perfect or could cause some disappointment. Cast aluminum valve covers help eliminate some of the over-tightening oil leak worries as they are less prone to being bent, but a straightened stock valve cover and taking care to not overtighten the bolts can be leak-free.
Old 02-16-2026, 02:00 PM   #6
Casper42
Casper42's Avatar
sounds like an odd thing to do, and waste of money. Powdercoating is for durability; there's zero reason for paint durability to valve covers.
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 02-16-2026, 06:30 PM   #7
JohnC67
I did valve covers for my Chevelle and had some powder left over so did my C10 valve covers. Used the HF gun. Blasted them in a benchtop cabinet and cooked in an oven I bought on CL for $20. Not necessary but I already had all the stuff. Also did a couple of my AC brackets. (I’ll be getting rid of the plastic fuel filter)
JohnC67 is offline   Reply With Quote
Old 02-16-2026, 08:01 PM   #8
'68OrangeSunshine
'68OrangeSunshine's Avatar
Not an expert at powder coating at all, but I remember a company that sold pre-powder coated Valve covers, Timing covers, Lifter covers, etc. They didn't offer Chevy Engine Orange. Someone enquired why? They said they could not warranty that the Orange would not turn brown under engine heat over time.
Old 02-16-2026, 09:17 PM   #9
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
^ Kind of strange, when the powder coat baking temp is above the temp any engine sheet metal part should ever see.
~Steven
Simi Valley, CA
Old 02-16-2026, 10:54 PM   #10
'68OrangeSunshine
Yeah. IDK. Maybe, With the technology of the day their Orange just turned brown on initial firing. Strange because I have some enameled steel coffee cups in that hue Orange, but that might be a different process.
As initially stated, I am in no way to be mistaken for a Powder Coating Expert.
For my money, VHT Chevy Engine Orange enamel works fine and lasts a long time, and is much less expensive.
Old 02-16-2026, 11:10 PM   #11
Steeveedee
Steeveedee's Avatar
Indeed.
~Steven
Simi Valley, CA
Old 02-17-2026, 06:00 AM   #12
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
When building the small block 400 for my truck I wanted stock valve covers. used one from old 350 and bought a used one. My friend knocked some dents out and sand blasted them then used Duplicolor Ceramic Paint with 2 costs of primer, 2 coats of Chevy Orange and 2 coats of clear. Paint is holding up well. Also used studs instead of bolts and the long hold downs. Only 3500 mileson the engine but no leaks so far.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 02-18-2026, 01:30 AM   #13
Rick Bollinger
I too powder coated my covers. I used Eastwood SBC orange. For me they turned out great. DIY Eastwood duel voltage set-up and a electric oven I too payed $20 for. I also did all of my small brackets and pulleys along with a bunch of bolts and nuts. Like others glass beaded in a Harbor Freight cabinet then sprayed with brake cleaner before coating. Baked at 365 degrees for about half an hour. So far no issues with anything coated to date. I cant imagine a 185 degree engine doing any damage especially the valve covers that would be considerlbly cooler. I am no expert by any means but was happy with the results.
Rick Bollinger is offline   Reply With Quote
Old 02-28-2026, 02:37 AM   #14
Extended Power
Extended Power's Avatar
The GM 572 crate engines come with cast aluminum powder coated covers.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 02-28-2026, 09:22 PM   #15
'68OrangeSunshine
Those look great.
Disregard Posts #8 and 10. The problem has been solved.
