#551 | |
Re: Long Time Coming......
I hope these measurements and pictures are helpful. If you need any more specific measurements, please let me know. ![]() The leading edge of the gas filler opening is 5-3/8" from the fender edge ![]() Using the center line of the 3/4" tape, it is exactly 3" from the closest slotted fender bolt hole. You can also see that the tape runs right next to that indentation in the fender. ![]() ![]() Using those measurements will get you to here for the filler tube/hose to get to the tank. ![]() On another topic, I thought I would share a useful tip for reinstalling body panels after paint. For years now, I have been drilling 1/8" alignment holes in a spot that is not very conspicuous. In the past I would use 1/8" drill pits to align the part while bolting things down. But not too long ago someone shared this tip, so I thought I would show you. I bought this Mini Pick & Hook Set on sale at Harbor Freight. Made by Pittsburgh. ![]() One already comes with a nice pointed tip, while the others are bent in some way. ![]() So I cut the tips off of the other three... ![]() And I used my bench grinder to sharpen the ends to a point. Now I have a set of four with a handle to install and remove with ease. ![]() And here in use.... ![]() ![]()
Glenn 1951 3100, Area51 1955 BelAir, 4EVER17 1987 R10, Ethel Copper Hill Rod & Custom http://67-72chevytrucks.com/vboard/s...d.php?t=829856 |
#552 |
glenn: thanks for the dimensions on the filler cap location. Now when the fenders come back I can complete that part. I like the idea of the pick & hook set. I've generally used small phillips head screwdrivers to align panels. But you can never have too many tools! LOL. When I test fit the fender I used a 3/8" bolt and nut from the inside of the bed, hung the fender & put a nut on the inside. After I got 2 other bolts in, I went back and unscrewed the top nut and bolt. the other alternative is to have my wife help out. She's great at that knid of thing.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's Bought in 1973 for $235.00. Had it longer than my wife & Kids!! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
