Old 01-06-2026, 10:25 PM   #1
Rich69shortfleet
Cylinder head upgrade for my SB400
Many years ago when I built the drivetrain for my '69 C10 I considered going big block but the costs scared me away. The truck was originally a small block truck so I would have needed everything including brackets, etc. which gets pricey. Anyway, I'm more of a small block guy anyway so I went with a '76 SB400 out of a '76 Blazer. I installed 5.7 rods and built a really nice just-a-notch-above-stock engine. The primary role of the truck was to be a nice driver and workhorse so I didn't want to hot rod it. It ended up with a Crower Baja Beast flat tappet cam:
Lift: .414 - I / .417 - E
Full duration 258/264
Duration at .050 204/208
Lobe separation 112
It idles pretty smooth and has a lot of low end grunt, pretty much done by 4500 RPMs though. Power runs through a TH350 with a mild shift kit and a 12-bolt truck posi with 3.73 gears. I've always thought a more modern auto with overdrive would be nice but I've never pulled the trigger on that. I retained the original tiny valve heads, just a 1.76 intake, but I did later upgrade the intake manifold to an Edlebrock Performer Q-Jet. The original quadrajet was used but slightly modified to run better than in it's original smogger motor configuration. Carb works excellently. The ignition is stock HEI with better advance weights for a more aggressive curve, 36 degrees all in by 2800 RPMs. I used the stock rams horn exhaust manifolds down to 2-1/4 dual exhaust with no crossover. I originally had a crossover downstream but it made working on some things tough and caused a broken exhaust manifold since the system wouldn't really rock with the engine. It has about 38k on the rebuild. Runs fantastic.
BUT, I'm bored. I've been wondering how it would do with much better heads. I've become a fan of AFR Enforcer heads and was thinking of adding these to the mix: https://www.summitracing.com/parts/afr-1011ft
They are as-cast aluminum heads with 2.02/1.60 valves. Would certainly improve breathing. Might cause the compression to go up as the smogger heads I have probably have a 76cc or larger combustion chamber and the AFR ones have 64cc chambers. I roughly calculate the current set up is running about 10:1 compression. I pretty much have to run 91 octane gas or I have to really back off the timing and it will still knock under load.
But I wonder if the heads would be a waste with such a mild cam. I could upgrade the cam too, but I still want the truck to pull and haul well and remain super reliable as it has been.
Rich69shortfleet is offline   Reply With Quote
Old 01-10-2026, 01:35 PM   #2
kwmech
Re: Cylinder head upgrade for my SB400
Never have I seen a 400 with a 1.76 intake valve, But what I would do is just get a good pair of 350 heads and have them gone through with the 1.94s and have the exhaust valve opened up to the 1.60. The 350s will have to be drilled for the steam pocket holes, but the machine shop can do that without blinking. I'd get the corvette rams with the 2.5 opening and work the exhaust to a single 3'' pipe with a dynaflo
Old 01-10-2026, 05:23 PM   #3
HO455
HO455's Avatar
You might look into the GM Vortec heads. 1988 to 1996. You would need to modify your intake or get a different one.
RIP Bob Parks.
Old 01-11-2026, 09:28 AM   #4
jjzepplin
jjzepplin's Avatar
I have been wondering the same thing about a swap on my 406. It just runs so good that I can't take it apart. I opened up the stock heads to 2.02s and bowl blended them. They have been fine for 20 years but need valve seals. I think pulling it apart will be a rabbit hole and would end up being a 6.0 LS swap. I think I will just let it run til it fails.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 01-11-2026, 02:31 PM   #5
Grounded63
AFR's are available with 65 or 75cc chambers. Vortec heads are going to be 64cc chambers.
Grounded63 is online now   Reply With Quote
Old 01-11-2026, 07:16 PM   #6
Rich69shortfleet
The AFR heads would by far be more cost effective and probably flow a lot better than anything GM ever provided.
Old 01-11-2026, 08:10 PM   #7
HO455
HO455's Avatar
That is probably true but all those improvements would be mostly wasted with the small cam. So then I'd want a bigger cam but, with all the flat tappet cam issues I'd have to have a hydraulic roller, and by the time I reached the bottom of the rabbit hole it would be a $4000 head swap. It might be better to get a good set of Vortec heads that will work nicely with a cam of that size. Modify the intake and be done for a $1500 or so.
That's only my opinion which along with a sawbuck will get you a steaming hot cup of joe just about anywhere.
RIP Bob Parks.
Old 01-11-2026, 08:54 PM   #8
Grounded63
According to the information provided by the OP. He will not be able to run the smaller chamber vortecs. Without, also a piston change. Plus, an aluminum head, will also help with his knocking/octane issue.
Old 01-11-2026, 09:19 PM   #9
HO455
HO455's Avatar
That is true and for personally for myself I would have to pull a head and determine the deck height and the piston dish/dome and valve relief CC's before deciding what heads I would use. Just too many variables to allow me to roll the dice and still be able to sleep at night.
RIP Bob Parks.
Old 01-12-2026, 12:20 AM   #10
Rich69shortfleet
Flat top pistons. No domes or dishes.
Old 01-12-2026, 01:25 AM   #11
Grounded63
Part of the problem with your current set up is. Small valve, oem cast iron heads, small RV style cam. 10:1 compression.
The general rule of thumb on a street vehicle. With stock type cast iron heads is 9:1 compression. Also with such a small cam. It's probably not bleeding off much of the dynamic compression. Because of the small amout of valve overlap.
Rule of thumb on a aluminum head street vehicle is 10:1. Going with a slightly bigger cam on your 400sbc. Probably won't hurt it any, on the low end. Probably would actually gain some. Especially with quality aftmarket heads.
Rule of thumb on a vortec head swap (if you could use them ) is 35-45hp iirc. AFR's wouldn't be any worse than that . . .
You also may want to look at the Brodix IK 180 line of heads. With some 1.6 rockers. Especially if you don't want to change the cam.
Old 01-12-2026, 02:36 PM   #12
Rich69shortfleet
Already considering 1.6 rockers if I do the heads.
Old 01-14-2026, 06:05 PM   #13
THI
THI's Avatar
My 2 cents for what is worth (not much). You are already around 10:1 compression with the 76cc heads - and yes you could get a 400 SBC with 1.76 intake valves from 1976 to 1980. I would consider the AFR head with a 75c chamber - aluminum head will help with the timing issue as will a fast-burn chamber. Once you have chosen a head you can think about a different cam if you wanted, as others have mentioned the cam you have is small and a little more duration would help bleed off some compression. If you still want to maintain low end grunt, I would keep the .050" intake duration between 214* and 220*.
THI is offline   Reply With Quote
Old 01-27-2026, 11:12 AM   #14
Rich69shortfleet
So the AFR heads I want have gone on sale and I'm really considering pulling the trigger but one more thing came up. My current set up has an Edelbrock Performer Q-Jet intake and of course a Q-Jet which I want to retain. The carb uses a divorced choke, however, none of the decent aftermarket heads have a heat riser port in them. The truck is pretty cold blooded as it is. I don't often have to drive it in cold weather, but today I needed it and it was about 15F out and it took forever to warm up even with cardboard in front of the radiator. Heads with no heat riser would cause the choke to take forever to open even in more moderate weather.
Old 01-29-2026, 11:01 PM   #15
Rich69shortfleet
Heads are on the way. They DO have a heat riser passage. Got an amazing price through Jegs.
Old 01-30-2026, 09:43 AM   #16
MySons68C20
MySons68C20's Avatar
I like the AFR Enforcer heads great choice!
Are you going to do a cam change and if so what did you decide?
I'm curious as I want to do a head swap and cam change on my 383.
Great thread!
MySons68C20 is offline   Reply With Quote
Old 01-30-2026, 11:20 PM   #17
GSP7
GSP7's Avatar
Thats a real mild RV cam almost stock
I like those ATF heads
GM Vortex heads are thin casting and real prone to cracking. Junk
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
Old 01-30-2026, 11:21 PM   #18
GSP7
GSP7's Avatar
No Snivelers
Old 01-30-2026, 11:53 PM   #19
Rich69shortfleet
Great thread!
Going to stick with the current cam for now.
Old 01-31-2026, 12:23 AM   #20
MySons68C20
Looking forward to your results!
Old 02-06-2026, 07:48 PM   #21
Rich69shortfleet
Got all the gaskets the other day. Heads will be a few more weeks, probably because I purchased the additional machining to have the steam holes drilled.
Got these today:
Old 02-11-2026, 11:17 AM   #22
scottofksu
scottofksu's Avatar
Holy crap, you are right next to me in Omaha! Let me know if you ever need an extra pair of hands! Excited to hear how the heads work for you as I have a set of ported AFR195s on my 383 that is currently awaiting installation in the truck.
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 03-26-2026, 10:14 PM   #23
Rich69shortfleet
AFR FINALLY got around to drilling those steam holes and shipping my heads to me.
Old 03-28-2026, 10:15 PM   #24
Grounded63
Very cool !
Looking forward to hearing about the results. Once you bolt them on.
Old 03-29-2026, 09:57 AM   #25
Rich69shortfleet
Originally Posted by Grounded63 View Post
Very cool !
It will be a while yet, but I will post back when the time comes.
