Old 09-03-2004, 10:41 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Power steering free play
How do I get rid of the free play in the steering wheel? I have power steering and about 1 1/2 inches of freeplay in my steering. It is quite annoying on either a windy day or an uneven road.
I'm afraid that I'm going to get pulled over for drunk driving just because the road is $h*t and my steering sucks.
Todd
toddtheodd is offline   Reply With Quote
Old 09-03-2004, 11:15 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Adjust the steering box. The adjuster is on top of the box.
Loosen the nut, tighten the screw, and retighten the nut.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-04-2004, 06:55 AM   #3
toddtheodd
toddtheodd's Avatar
You wouldn't happen to have a pic of the correct nut would you? Isn't there 2 nuts on the top?
Old 09-04-2004, 07:50 AM   #4
MOTHERTRUCKERS
The nut is the only one with a slotted stud for a screwdriver. Loosen the nut and screw the stud clockwise a quarter turn at a time until the slop is gone, be careful if you go to far it will damage the worm and sector.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-04-2004, 08:19 AM   #5
toddtheodd
toddtheodd's Avatar
That doesn't sound so hard, which means that after I do that my hood will fly off and the truck will burst into flames.
I will try not to kill the worm.
Todd
Old 09-04-2004, 08:36 AM   #6
Tx Firefighter
Be a lttle careful. I have a 3 inch scar on my hand where I was trying to loosen that nut with a wrench when it slipped off and my hand hit the fan blade. It cost me better than a dozen stitches and the pisser is that I had to drive the truck to the emergency room with a loose steering box because I didn't get it adjusted.
Old 09-04-2004, 08:45 AM   #7
toddtheodd
toddtheodd's Avatar
Luckily I have electric fans so that shouldn't be the problem that I WILL have. I'll probably end up messing up the worm. I'll be extra careful though.
Old 09-04-2004, 09:06 AM   #8
toddtheodd
toddtheodd's Avatar
OK, I went out to take a peak at it (I'm at work) and it looks more like a bolt with an allen wrench hole in it. Is that the one? Or is there a "screw" down inside of that "hexagonal" hole?
Old 09-04-2004, 09:24 AM   #9
Tx Firefighter
That should be it.
Don't sweat messing it up too much. What Mothertruckers was saying is that if you get it too tight and drive it around awhile, it will damage the gear. Basically, just adjust it a little at a time until you get the play dialed out of it. Once you get it adjusted pretty close, lock it down and stop. Don't get greedy and try to take all of the slack out of it.
When you get done and go drive it, if you have a weird sensation through the wheel when steering directly off of center, loosen it a little till it goes away.
Old 09-04-2004, 03:42 PM   #10
Rusty Rider
Rusty Rider's Avatar
you found it . same as mine. i did this last week as well.
72 long fleet (WIP)
00 Astro every day
Rusty Rider is offline   Reply With Quote
