Old 09-04-2004, 11:27 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Question Smoothing out sheetmetal????
What do you guys use after you welded something on, grinded the welds down to smooth the metal out? Sand paper, higher grit on the angled grinder? Or just be real soft with the die-grinder?
check out my work http://67-72chevytrucks.com/vboard/s...965#post943965
Alexis is offline   Reply With Quote
Old 09-05-2004, 03:17 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If your welds are really good or you managed to weld it from the backside (not possible where you are welding on your truck but on some panels this is possible) you can use a right angle die grinder with the small spiral loc discs in 80 - 120 grit. I use my 4-inch right angle grinder to knock down my heavy welds and then finish them off with the air angle and the 80 - 120 grit disc.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-05-2004, 10:27 AM   #3
Gee_Emm
Get some flap discs to go on your 4" angle grinder, they work great, I would never go back to anything else. For finishing in tight areas I use a angle die grinder with a 2" disc.
Gee_Emm is offline   Reply With Quote
Old 09-05-2004, 11:35 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Those Flap Disk Are The Bomb!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-05-2004, 12:01 PM   #5
Alexis
Member since 2000
Alexis's Avatar
sweet. thanks for the tip. Gonna have to stop by the hardware store.
Old 09-05-2004, 12:30 PM   #6
dropdprpls10
dropdprpls10's Avatar
i use the flaper disks like Gee emm posted.. just gotta watch you dont lay on it to hard.. might not happen to you on a older truck but on the new sheet metal on late models its thinner and you can warp it.. if you watched trucks stacie used them when he was showing how to shave door handles and gas doors!!
dropdprpls10 is offline   Reply With Quote
Old 09-05-2004, 07:41 PM   #7
Alexis
Member since 2000
Alexis's Avatar
Home depot didn't have then, the OSH down the street from them didn't have them. Stopped by the OSH near my house to pick up some stuff and what'da you know, they had them. Picked on just 2. Just got to be nice with them and they do wounders. thanks guys!
