Old 09-08-2004, 06:25 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Carrier
What is the quickest easiest way to get the carrier out of the 12 bolt rear end? I need the ring and pinion off of it and I have never taken a rear end apart before. MACKL gave me some great instructions on the spider gears inside the carrier, but now I need to know how to get the carrier out.
Todd
toddtheodd is offline   Reply With Quote
Old 09-08-2004, 06:45 PM   #2
Sweet72
Sweet72's Avatar
GM shows a special spreader tool in the chassis overhaul manual that actually spreads the housing for carrier removal. I'm sure someone here has a "trick of the trade" for those of us who don't have access to the special tool.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-08-2004, 06:51 PM   #3
flip66
flip66's Avatar
http://www.2quicknovas.com/happyrearends.html
flip66 is offline   Reply With Quote
Old 09-08-2004, 08:29 PM   #4
toddtheodd
toddtheodd's Avatar
Originally Posted by flip66
I'm hoping (guessing) that all of that 10 bolt information is the same for a 12 bolt.?.?.
Todd
Old 09-08-2004, 09:04 PM   #5
67_SS396
Using that as a guide will get the carrier out of your housing. Once you dig into it, you'll see that it's not hard at all. No special tools needed.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 09-09-2004, 12:42 AM   #6
flip66
flip66's Avatar
todd sent you a pm
