Old 09-11-2004, 10:09 PM   #1
sdmahr
sdmahr's Avatar
@#$%&* Crossmember !!!
I'm removing a manual trans cross member and son-of-a biscuit eater those rivets are some tough stuff ! Air chisel, grinder, sawz-all, and it still isn't out of there ! Sure wish I had a large gas powered wrench, (torch ! !)
Maybe a few more hours tommorrow will get it !
sdmahr is offline   Reply With Quote
Old 09-11-2004, 10:22 PM   #2
Zeke
Active Member
Center punch the head and drill out. If you use a big enough drill the head will pop off. Even if it doesn't it makes it easier to chisel off since there will be less material to chisel.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 09-11-2004, 10:22 PM   #3
rage'nrat638
rage'nrat638's Avatar
Thumbs up
grind it flat with the frame...center punch it.....drill away.....
rage'nrat638 is offline   Reply With Quote
Old 09-11-2004, 10:57 PM   #4
MACKL
Almost done!
MACKL's Avatar
Yes, the blue tip wrench is the way to go. Those rivits will be gone in 60 seconds.
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 09-12-2004, 10:05 AM   #5
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
I've got a 16 yr old for rent that worked real well on getting ours out. Comes with an air chisel, ear protection, hammer & punch. You provide the compressor & air lines.
The down side is that it takes him about 2-4 hours for the job, and you have to feed him for that period, which may cost more than your truck.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 09-12-2004, 10:12 AM   #6
JoetheMobster
Listening since '86
JoetheMobster's Avatar
SSOW
LMFAO!!!
2007 Saturn Aura - hey it WAS a GM product
JoetheMobster is offline   Reply With Quote
Old 09-12-2004, 11:14 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I used a grimder and a air hammer to knok my cross member rivit's out took anot an hour...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-12-2004, 11:40 AM   #8
Gee_Emm
Thats what I did and it still took me an hour and a half to get mine out.
Gee_Emm is offline   Reply With Quote
Old 09-12-2004, 04:38 PM   #9
sdmahr
sdmahr's Avatar
Thumbs up
With the 350 V8 on the stand, and the tranny in the corner cheering me on, the crossmember is OUT ! Wow, what a job ! The rest of this project ought to be a dream after that ! Thanks for the advice and support.....now I'm gonna get to bolting up the auto cross member and placing that 350 in ! (Gives me chills !
Old 09-14-2004, 10:49 AM   #10
raphyel
An angle grinder will grind them down to the frame then either a punch or an air hammer will finish the job.
raphyel is offline   Reply With Quote
Old 09-14-2004, 11:07 AM   #11
ChevyDude
I guess this is what I have to look forward to. I also have a new 350 sitting on a stand, a new 700R4 in the corner, and the auto crossmember...all waiting to be put in. I'm going to go at it this coming weekend. Wish me luck!!!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 09-14-2004, 11:49 AM   #12
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Is the old cross member still in one piece and useable ? What are you going to do with it, If its complete I'd be interested in it. Let me know
Steve
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 09-14-2004, 05:25 PM   #13
sdmahr
sdmahr's Avatar
I couldn't get the member out from between the frame rails so SawzAll to the rescue ! Cut that SOB in half. Sorry !
Old 09-14-2004, 06:21 PM   #14
ChevyDude
You can have mine...if I don't have to destroy it. It's a 3 on the tree tranny mount.
Alex
Old 09-14-2004, 07:43 PM   #15
Blue68
Blue68's Avatar
Blue tipped wrench or plasma cutter are the tools of choice. If that isn't available, here's a tip for manual removal. Use a cutoff wheel and make an X on the head of the rivet (cut deep). Then use an air hammer/chisel to cut the head off. Then punch them out. I've found this to be a little easier and definately faster than drilling the head off (I usually miss the center).
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
