Old 06-18-2002, 11:15 PM   #1
matt_field
matt_field's Avatar
no brake lights.. need help
on my 1967 chevy, i have tailights when my head lights are on, but no tail lights. wireing is new from the rear axle back what should i check for? also i only have one blinker the other just sticks on but both bulbs are good
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 06-19-2002, 12:53 AM   #2
WORNBRAKES
I spent 2 days last week with the similar problem. The last thing I did is run a wire from the back of the taillight assy. where the harness clips over it, straight to a good ground. That fixed the problem I had. My specifics were: no taillights, no brake lights, and when I used turn signals I had taillights. The front harness and lights were great and needed no attention. I lost the ground because the weekend prior I was following a lifted 4x4 with my stock 2wd were I shouldn't have been. (it was fun though) I smacked my tow package about 7 or maby a good 10 times and somehow lost the ground back there. lol These guys helped me out a lot and if I knew how to post a link to my thread here I would. It may be about 8 or 9 pages back. I hope you get yours soon.
Mario and Mandy
Hughesville, MD 20637
69 C10 305/350
71 K5 Basket case
75 K10 Rescue **Parting out**
77 MG Midget **Parting out**
15 6.7L Cummins
WORNBRAKES is offline   Reply With Quote
Old 06-19-2002, 01:02 AM   #3
ibjoker69
hahaha
Do you mean your brake lights don't work? You state that the tail lights work when the head lights are on. If so it could be the brake light switch under your dash is not making a good conection. In this case the tail lights will work and the turn signals will work but you will not have tail lights. Hope this helps, Joker69
69lwb, 29 A coupe hotrod, 55 chevy hardtop,
ibjoker69 is offline   Reply With Quote
Old 06-19-2002, 11:49 AM   #4
dwaite72lnghrn
I would go with the ground. I had similar problem push brake pedal and the turn signal would stop flashing, turn on lights and rear were dim. I ran a ground strap (6gauge I had laying around) from the center of the bed cross member, back by the bumper (hole already) there to the frame about six inches back from the bumper on the drivers side (hole aready there) problem solved.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-23-2002, 11:38 PM   #5
matt_field
matt_field's Avatar
thanks alot... i ripped apart everything to find it, and would you know it... it was really easy! i looked up under the dash and it was unhooked from the harness, and the ground was bad. thanks alot for your help though
1967 swb 2wd 427bbc
1968 4wd shortbox
Old 06-29-2002, 01:15 PM   #6
WORNBRAKES
ttt
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-29-2002, 06:44 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Why are we going ttt with this? He found the trouble.
Old 06-30-2002, 01:33 AM   #8
WORNBRAKES
duh, but to tell you the truth longhorn, I don't recall doing it. Maby I am loosing it. LOL Glad you found and fixed the problem.
Mario and Mandy
69 C10 305/350
71 K5 Basket case
15 6.7L Cummins
Old 06-30-2002, 01:58 AM   #9
Longhorn Man
LOL, I've done this too.
