Under construction!
Everything on my truck is polygraphite except the 4-link/panhard bar. How would PST units compare to GM mounts? More vibration or what? Thanks for any advice.
2001 Silverado bagged on 22's. *Sold* |
I dunno about GM ones..put I have a set of Energy Suspension Polyurethane motor mounts.
Under construction!
Did you notice a difference between the original and polyurethane units, Tim?
I have energy suspension poly engine and tranny mounts on my S10. When the a/c is on, or its idling in gear it is trying to shake itself to death. I will never have another set of poly engine mounts. I can only imagine how bad it would be if you had a good sized cam. Its really annoying, I want to change it back to rubber, but dont have the time or $$ as I have about $150 in these. They required custom made frame pads.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
You get what you pay for
![]() Join Date: Dec 1999
I have Energy Suspension engine and tranny mounts in my 85. All I noticed was more vibration. When at idle you can feel the engine running but it doesn't shake itself to death by no means and I have a Comp XE268 cam.
Mike 1985 Chevy C-10 |
Garage Queen Material
i have energy suspension engine mounts and the stock rubber tranny mount(for now). it does rock back and forth a little bit(tiny tiny bit). but i like it
I was always told, that if you run poly engine mounts, you MUST run a rubber tranny mount, or else SOMEWHERE SOMETHING will crack/break. I have more vibration than rubber, I'll say that..but it's not bad.
y not run solid motor mounts?
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
california fill
I run energy suspension polyurethane motor/spring/trans/body/swaybar etc etc and yes you will notice more vibration! Would I do urethane motor mounts again? probably.
If youre looking for ultra comfort in your vehicle, Id go rubber. just my 2 cents pc |
Under construction!
Thanks for the input, everyone. Looks like I'll be purchasing PST motor mounts soon.
#11 | |
