09-18-2004, 06:17 AM | #1 |
body alignment specs
I'm rebuilding a 67 SWB frame off. Is there a manual that could give me measurements of body panels for the sake of alignment. For instance I've got to replace on the cab the rocker panels, cab corners, dogleg (that is the lower rear fender mount and lower door mounting), and toe kick. because some of the panels ore so far gone I have no real reference points to go by.
I'm thinking at this point what I have to do is tack replace the dogleg, align the door to the cab then hang the front sheetmetal to insure the dogleg is in the proper position align it to the doors and cab, after that remove the front clip and door again then install the rocker and cab corner and then reasemble to insure that everything fits. Am I out in left field here? Any better ideas on what approach to take? |
09-18-2004, 07:31 AM | #2 |
I suspect that the cab was assembled using fixtures. The Assembly Manual
has lots of pictures but no usefull dimensions for installing the lower pillar. I can get some dimensions off of a cab for you. I believe that we could use the cab rail for the left/right location and the firewall for the fore/aft location. For mockup purposes where clamps cannot be used we use self drilling sheet metal screws to hold the part in place, (welding up the holes when finishing). Post or PM if you would like to try this. Jim |
09-18-2004, 08:05 AM | #3 |
Have you tried calling and getting the Restoration Pack from Chevrolet?
It's free for a phone call. Have the vin number ready when you call. 1-800-222-1020
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
09-18-2004, 11:00 AM | #4 |
Restoration pack? What is that?
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
09-18-2004, 11:36 AM | #5 |
Restoration pack gives you the specs when the truck was built.
They also give you info for parts
09-18-2004, 04:34 PM | #6 |
What kind of specs do they give you? I have never heard of this.
