Old 09-20-2004, 09:32 PM   #1
Nima
Blue 67
Different wiring harnesses
I am making a list of the things I need to do for my truck and one of them is wiring. What's your opinion about different brands of wiring harnesses? their prices varies alot. I am talking about Painless, EZ-wiring and keep it clean wiring. It seems EZ wiring is the cheapest. I am not good at wiring and electrical therefore I need something with easy instruction.
Thanks.
Nima is offline   Reply With Quote
Old 09-20-2004, 09:42 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Thanks.
MINE CAME WITH A NEW ONE ON IT WHEN I BOUGHT IT FROM JOE IN CALI,
YOU COULD PM HIM & ASK WHO MADE HIS, IT IS VERY NICE. (1972BLAZER)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-21-2004, 02:29 AM   #3
Nima
Blue 67
Thanks for the info.
Old 09-21-2004, 02:42 AM   #4
ljbear
ljbear's Avatar
If you're looking for easy look at the M&H harness. I've used a number of them on these trucks and they fit and are a breeze to install. Everything is like original and there is no cutting. If you're doing something more custom with aftermarket accesories like windows or door locks then look at Painless
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 09-21-2004, 04:06 AM   #5
68LSS1
68LSS1's Avatar
My vote is for Ron Francis Wiring.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 09-21-2004, 01:31 PM   #6
Kleantouch
Kleantouch's Avatar
I bought the Painless 68-72 harness and the a/c add-on- it was a pretty easy install- instructions were pretty straightforward and the tech line is an 800# and the guys there are pretty knowledgable- I bought it because I thought the fuse block would go in the original hole- well, it did- but I had to enlarge it first to fir- that was the only drawback- set up for voltage regulator, single wire alt, points disty, HEI, ready for most anything. I would have spent the extra money on a ron francis had I not seen the Painless chevy truck harness. Good luck- wiring isn't that hard- getting a good ground is.
Kleantouch is offline   Reply With Quote
Old 09-21-2004, 04:04 PM   #7
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
If you are looking for just plug in simple, the Painless kit does not quite do it. You have to shape, route, tape and secure the harness and terminate a lot of connections. Like Kleantouch said, it is set up for lots of accessories that are not in these trucks. You gotta figure out what you want to keep and store for future use and what you want to flat out remove. If you are not one for electrics, try something that is allready fabbed up so you just have to remove and replace. Wish I could help you with name brands but Painless was all I looked into. I was foolish just thinking the major name-brand Painless was "the $h!t". Had I to do it all over I would have weighed my alternatives like you.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-23-2004, 12:16 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I have heard very good thing's about the ron francis harness' never installed one but have seen the in a number of street rod's and they all looked of very good quality...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 09-23-2004, 02:05 AM   #9
Nima
Blue 67
Good info.
thanks
Old 09-23-2004, 12:37 PM   #10
MOTHERTRUCKERS
M&H is the best for these year trucks, it almost installs itself.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-26-2004, 11:00 AM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
I second that.
M&H has got it "wired." They are American made, perfect stock hook ups, and the technician who builds your harness, actually puts his name on the loom.
'68OrangeSunshine is online now   Reply With Quote
