Old 10-01-2004, 06:01 PM   #1
Truckhead
18436572
Truckhead's Avatar
I will pay for this info (70 C/10)
Having no luck (except for one helpful comment) on this problem, I will send $10 Paypal to anyone who can give me an understandable schematic of:
70 C/10
Wiring for stock 2 speed wipers from input at the wiper switch to the connectors to the motor.
Basically, I have the connectors going into the wiper motor in a box. Since the motor is mounted, I think there are 3 places to plug in. Hard to tell.
I have the wiper switch in that box. I believe the dark blue wire (center one of the 3) feeds power into the switch. That leaves 2 output connectors there. I need to know how to wire it up.
Thanks, Paul
Truckhead is offline   Reply With Quote
Old 10-01-2004, 06:04 PM   #2
FormerMember
Not sure if this helps:
FormerMember is offline   Reply With Quote
Old 10-01-2004, 06:05 PM   #3
FormerMember
No picture attached?
Old 10-01-2004, 06:09 PM   #4
cdowns
cdowns's Avatar
i fail to see how a taillight wiring diagram is going to help his wipers
Old 10-01-2004, 06:12 PM   #5
FormerMember
Look at the diagram above it...
Old 10-01-2004, 06:18 PM   #6
cdowns
cdowns's Avatar
nice engine compartment diagram !! still notjing with the wipers ,try one more time
Old 10-01-2004, 06:43 PM   #7
cdowns
cdowns's Avatar
OK looking at the wiper switch youve got 3terminals in line 2close to each the other off by itself the lonely terminal gets ltblue the middle dkblue the other outside one is blackie
now lookin at the wiper and washer assy on the back there's 2 terminals dark blue on top then there's a yellow that comes from the fuse box with 2 plugs 1 goes on the bottom ,then on the right side of the pump there's 3termilals from back to front first goes blakie then lt blue then yellow
if this makes sence to you and it gets your wipers runnin send the $10 to josh for board upkeep
Old 10-01-2004, 06:47 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Someone give him the info he wants and make him send the 10 bucks to Josh to support this place instead.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-01-2004, 06:58 PM   #9
cdowns
cdowns's Avatar
HAJAHHA I BEAT U TO IT !!!!
Old 10-01-2004, 06:59 PM   #10
FormerMember
I am looking for the cab schematic I had...
That was my plan, to send the money to Josh.
Old 10-01-2004, 07:18 PM   #11
neonlarry
neonlarry's Avatar
Check here:
http://www.geocities.com/chevroletc1070/instrum2.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-10-2004, 08:52 PM   #12
Truckhead
18436572
Truckhead's Avatar
Thanks CDowns!
Sorry I didn't get back sooner.
Old 10-10-2004, 10:42 PM   #13
68C15
blood type; Retumbo
68C15's Avatar
FYI, the switch grounds the ckt. & supplies power for washer.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
