10-04-2004, 04:55 PM | #1 |
Weekend Warrior
73+ ball joints in my 69
I have a 69 1/2ton with the usual drum brake/non-power front end. I know that i can bolt the whole crossmember from a 73+ into my chassis with very little modification (the two bolt holes that don't line up)
my question is will 73+ ball joints bolt/press into the 69 Upper and Lower Control or "A-Arms". I have a 73+ front end but the upper ctrl arms are Rotted (as I live in New England) and the control arms look the same size (other than the bushings) so the question is: will 73+ ball joints bolt/press into my 69 control arms so that i can use the disc brake setup out of the 73+ (I know that i have to also use the steering components from the 73+ because they are different) Any Info is appreciated Thanks Andy |
10-04-2004, 06:20 PM | #2 |
67-72 parts collector,…
,... the answer is yes.
10-04-2004, 06:43 PM | #3 |
Weekend Warrior
thanks
Thanks -
one more question - I was reading some earlier post and one or two people mentioned doing this and said they had problems with the alignment???? why would it change the alignment - i know i have to have it aligned anyway - but is it that much different that it creats a problem and other posts have said they done this swap with no problem. |
10-04-2004, 07:57 PM | #4 |
Fabricate till you "puke"
I have 73 up balljoints & spindles on my 69....the parts are bolt in. The only issue i have heard of is the steer stops are a little different from drum to disc, & you may shorten your turn radius a bit. (easy fix with a grinder). my 69 was a 3/4 ton, swapped to 1/2 ton suspensoin.....the 1/2 ton balljoints bolted to the orig TOP arms, & the lower arms were swapped for a 71-72 set(due to hole size 1/2 to 3/4 ton). The '75 lower balljoints pressed right into the lower a arms. you have the steer linkage covered(use all of it from the later truck). there was one guy that reported alinement problems on this type swap......my guess is that he had a bent arm or something? my truck has run 10-12000 mi since the swap, without problems best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
10-05-2004, 08:39 AM | #5 |
Weekend Warrior
Thanks.
Appreciate the help. I'm a Newbe to the 67-72 crowd. I just picked my truck up a few weeks ago and am going to make it my daily driver. |
