Old 10-05-2004, 05:42 PM   #1
Lobo'74
Lobo'74's Avatar
Collapsable steering column?
When did Chevrolet start putting the collapsable steering column in? I have a '67 and wanted to do a tilt column if possible. Since the old one would be replaced what is a closest to an easy bolt in replacement that has the nice safety feature of collapsing when in a collision?
I know, just don't get hit and its not a problem, right?
"Truck"
'67 small window
'79 350 .030 over, LT1 "clone"
Lobo'74 is offline   Reply With Quote
Old 10-05-2004, 07:49 PM   #2
jmanz69
Careful, they attack...
jmanz69's Avatar
I think our trucks had the colapsable column. My 69 had the 2 part shaft in it when I took it out. It's the shaft from the steering box to the bottom of the column. You can see it in the engine compartment.
jmanz69 is offline   Reply With Quote
Old 10-05-2004, 07:54 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
my 68 has a colapsible steering shaft. but when puting in the power steering i couldnt get to move for the life of me
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-05-2004, 07:57 PM   #4
jmanz69
jmanz69's Avatar
By colapsable they mean it will colapse on impact, not move to suit your needs. You will have to break the plastic rivets that hold it up, then drive it down to the size you want. It's a PITA.
Old 10-05-2004, 08:28 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Acording to what i have read, and the few 67/68 trucks I have seen, it started in 69.
To do a tilt, you'd need the column naturally, and then the intermediate shaft. The one between the gear box and the column it's self. If you go with a van unit, you have to colapse it a couple inches to make it fit. Real easy to do, with the intermedeate shaft removed, stand it on end then pick it straight up a foot or so, and let it drop. that should break the nylon inserts. There is no reason to install new ones, it will do absolutly no good and a waste of time to do so. (I've heard many say it is needed) Your shaft will still have the colapsable feature, but it won't colapse as far.
Old 10-05-2004, 10:25 PM   #6
68w/sbc406
68w/sbc406's Avatar
believe me i didnt ask nicely. i drilled out the nylon pin things and hit it with a hammer. didnt move.
Old 10-06-2004, 12:59 AM   #7
junkyardjohn
junkyardjohn's Avatar
HIT IT HARDER... IT'LL MOVE. SOMETIMES YOU HAVE TO HAMMER THE SNOT OUT OF IT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-06-2004, 08:48 AM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I heated mine with a propane torch and the rivits bubbled out. A slight tap of the hammer after that and its like butter. Note to self, don't pick up steering shaft with ands after you heat it. ouch.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 10-06-2004, 09:41 PM   #9
68w/sbc406
68w/sbc406's Avatar
thats like dont pick up that bolt that you just cut off right?
Old 10-10-2004, 09:57 PM   #10
purple gas
I just smacked mine on the floor,, several times,ok,, quite a few times, and it moved enough to fit.
purple gas is offline   Reply With Quote
Old 10-10-2004, 10:04 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Weren't you the guy who posted this morning about your intermediate shaft being too long causing not enough belly room?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-10-2004, 10:43 PM   #12
purple gas
yup, that was me,, when I get answers to questions, I act on them,,, thanks fer the tip
