Old 10-06-2004, 07:40 PM   #1
lamar
lamar's Avatar
Cool TACH Problems help
OK I wired up the tach, one wire to dist. - one wire to the fuse panel( marked ing. unfused. When I crank it up the tach will move with the engine rpms but at I think much lower value, also at idle the tach read o. Do I just need to adjust it with the screw in the back?
lamar is offline   Reply With Quote
Old 10-06-2004, 07:47 PM   #2
1-PU70
1-PU70's Avatar
Did you conect a ground wire?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 10-06-2004, 07:50 PM   #3
lamar
lamar's Avatar
I was thinking it was grounded by the ground wire in the harness. But I did try to ground the thrid prong on the back to a good chasis ground.,
Old 10-06-2004, 08:26 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
Need a little more info. Is it an aftermarket tach or a stock tach? V8 or 6 cyl? I'm not saying I can answer all your questions, but I may be able to help.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-06-2004, 08:28 PM   #5
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
If it's an aftermarket,check to see that it is set to the proper cylinder setting.4,6,8 cyl.I bet that's the problem.Some stock tachs have this setting too.
Prolly on the back,may have to remove the cover to get to it
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-06-2004, 09:26 PM   #6
lamar
lamar's Avatar
Stock tach, new goodwrench performance deluxe 350. It came with dist. wires and plugs. HEI dist,
Old 10-06-2004, 09:35 PM   #7
68 Stepside
huh?
If the tach is an original 6 cyl tach, it'll read odd, but I think it should read high From what I've gathered, there's an adjustment screw on the back of a stock tach that you can mess around with. Use a known good tach of some sort, designed for a V8, and adjust your stock tach accordingly. Best of luck.
RIP El Jay
Old 10-06-2004, 09:39 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen a stock one act like this. I'd rev the sucker to about 3500 RPM and hold it, and the needle would slowly rise to about 1000 RPM.
We chucked it and slapped in an aftermarket one.
Old 10-06-2004, 10:08 PM   #9
lamar
lamar's Avatar
Thanks guys for the help. Iguess I'll play with the adjustments and see what happens. Just made the normal nightly run to the gro. store and the tach would move a little at normal rpm and speeds around 0-500 but when I hammer it the tach seems to read closer to what it should, but as soon as I let off the gas the tach returns quickly to 0-500 range. Maybe it needs adjusting. Thanks
