Old 10-06-2004, 08:50 PM   #1
jrb56
BBC into 62 SWB
Couple of questions.
How to get a BBC in a 62 stovebolt hole? Frame mounts motor mounts, etc...??
Are the torsion bars stroing enough to use temporarily?
Will I have to move the trans crossmember? I am going from 3 on tree saginaw to muncie M-20 on floor....
Thanks for any help.
Joe
62 Stepside swb
468 bbc
Muncie M-20
Cicken poop
jrb56 is offline   Reply With Quote
Old 10-06-2004, 11:49 PM   #2
cochran63
cochran63's Avatar
I have the same questions you have except my 63 has the newer style front end. I am fixing to put in a 439 big block and am also wondering what type of motor mounts to use.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 10-07-2004, 02:54 PM   #3
fatboy63k10
some reading for you. same info applies to bbc or sbc. Some move the perches forward and inch or two for Hei distributor clearance.
http://www.geocities.com/vapershing/perches.html
Also, follow this thread-
http://www.chevytalk.org/threads/sho...rue#Post861659
454 fleet
http://www.picturetrail.com/fatboy63k10
fatboy63k10 is offline   Reply With Quote
Old 10-08-2004, 01:55 PM   #4
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
The torsion bars should hold up on a BBC, since the same front suspension is in the GMC's with the big 305 V6s.
The best spot to mount a BBC is to have a 2 inches in the back of the engine for clearance so there's easy access to puling the distributor, and valve covers. Also the radiator will need to be a 4core to keep the BBC cool. For engine mounts, you'll need the engine mounts that originaly came off the engine.
I hope this helps.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
