Old 10-08-2004, 11:06 PM   #1
Chevyguy111786
I Want Posi Traction!!!
yeah that's about it, i want a posi. What's a good unit to get? Where can i get one....would rather buy a good used one due to cost, but either is fine. I have a 78 chevy 1/2 ton, originally a Big 10 but now it has a mild 350. don't know the gear ratio, but was told by PO is was 3:42. any idears?
Chevyguy111786 is offline   Reply With Quote
Old 10-08-2004, 11:08 PM   #2
ocbaud
Garage Queen Material
i left two 20' marks the other night leaving my parking lot at work
i came back the next day and was like..." i left two marks??? "
haha
to bad that never happens usually
ocbaud is offline   Reply With Quote
Old 10-08-2004, 11:14 PM   #3
Chevyguy111786
haha! i can leave two....when it's raining...DOH!...it's not real important, but somethin i'd like to have....but only for the right price type of deal.
Old 10-08-2004, 11:51 PM   #4
81shavedtrk
12 bolt or 10 bolt?
11.98 @112mph Stock suspension and little tires.
81shavedtrk is offline   Reply With Quote
Old 10-09-2004, 11:25 AM   #5
86 Red_Bowtie
86 Red_Bowtie's Avatar
I have a Eaton posi with 3:73 gears in my truck and it ran about $400 for the unit.I like it beats having those one legged wonders.
Sean
Midwest All Truck Nationals, Riverside, MO - 2008 - 2015
86 Red_Bowtie is offline   Reply With Quote
Old 10-09-2004, 11:37 AM   #6
Chevyguy111786
12 bolt..forgot that part, i think anyway, guess i need to check gear ratios and bolt pattern...what's the easiest way to check gear ratio?
Old 10-09-2004, 11:59 AM   #7
86-C10-V6
Shadetree Mechanic
86-C10-V6's Avatar
Unless you want to change the Ratio
the ratio is not that important, since you will take the ring gear from your existing differential and bolt it on the new posi differential.
For an all around posi unit, I think the Eaton posi is the best thing going. Doesn't create absolute lockup since it is clutch operated but is less noisy and has a proven reliability record. It's also rebuildable which is its advantage over the Auburn Gear differential.
My Auburn has held up well, but I don't have enough HP to really hurt it.
There is a lot of internet sites with info on Posi differentials. Just google it up and do some research.
If current differential is open, which it sounds like it is, something like the "lock-rite" is much easier and most likely cheaper to install.
Dave M. (Hacksaw)
86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance
89 GMC S-15 Extended Cab 4x4, 4.3L, FI
98 K1500 Xcab, 5.7L, 3.43 Gov-Lok
86-C10-V6 is offline   Reply With Quote
Old 10-09-2004, 04:36 PM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Get posi. It was the first thing I did to my truck. I went w/ Eaton kit that a regular seller had/has on Ebay, cost like 650 included posi, choice of gears(I did 3.42), bearings, seals, etc. All new.
I also had new axles installed as I was converting from 6 lug to 5. Total cost about $1250 with me pulling the rear out and putting it back. Love leaving 2 black stripes
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 10-10-2004, 07:14 PM   #9
STEPSIDE_84
salvage yard in nh sells original gm posi(limited slip) for $125
used ones on ebay are usaully around 150+ship
STEPSIDE_84 is offline   Reply With Quote
Old 10-10-2004, 11:47 PM   #10
SanitysBane
if i were you, forget a posi, they have clutches that ware out, plus you have to put in a special aditive in your rearend grease, i would go with a detroit locker for the fact that it doesn't ware out, and no special rearend grease is needed.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 10-16-2004, 04:01 AM   #11
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Arrow
I did alot of research awhile back on posi's. Easton seemed to be the best since it is rebuildable unlike the Auburns.
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
