Old 10-09-2004, 02:40 AM   #1
modmach1
modmach1's Avatar
Z-Frame and lowering questions
What would it say when you Z-the frame? I know the basics, but have does that look?
I have a 4" drop rear (lowering hanger kit from Belltech). What can i do to make it even lower without air? Air is coming but not right now.
I have seen 3" drop spindles for the front for around 300$ Anyone know of places that is cheaper`?
Best Regards from Norway
http://www.moldestuket.com
1971 Mustang Mach-1 429 CJ-R
1973 Mustang Mach-1 289
1975/71 Pontiac Firebird Formula 400
1978 Chevrolet C-10 Fleetside Longbed Scottsdale
1980 Pontiac Phoenix
modmach1 is offline   Reply With Quote
Old 10-09-2004, 12:23 PM   #2
SCOTI
SCOTI's Avatar
The drop spindle price is average. They typically are priced between $250-350. You can cut 1 coil off for another 2-3" of drop depending on the amount of spring sag.
For the rear, a flip kit gets 5-6" of drop depending on the thickness of the spring pack. Add some drop shackles for 1-2" more.
If you do the flip kit & shackles, you'll want/need to do a c-section.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-09-2004, 05:35 PM   #3
modmach1
modmach1's Avatar
where can i buy these C-Frame brackets?
Old 10-09-2004, 07:26 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I believe those are "Western Chassis" brand. You could also get your flip kit from them. Good stuff. You will have to re-install your stock hanger in the front and stock rear shackle for a 5-6 inch drop. Re-install the front hanger only and you will have a 7-8 inch drop,... (with the Bell tech shackle) Good luck,... lolife99.
Keith
Convert to disc brakes.
Old 10-09-2004, 08:28 PM   #5
SCOTI
SCOTI's Avatar
I have a pair of those on my parts shelf & possibly will be selling them in the next couple of weeks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2004, 08:06 PM   #6
loweredd
www.loweredd.com
loweredd's Avatar
modmach1, I Z'd the front of my frame. I have some pictures on my website if you want to check it out. Ask me any questions if the pictures dont answer all your questions.
loweredd is offline   Reply With Quote
Old 10-13-2004, 06:19 AM   #7
modmach1
modmach1's Avatar
Interesting ! What kind of other parts must i get to flip the axel on top?
Old 10-13-2004, 06:43 AM   #8
modmach1
modmach1's Avatar
DAMN
That truck sits low !! How long time did you use?
Old 10-13-2004, 09:42 AM   #9
loweredd
www.loweredd.com
loweredd's Avatar
I worked on it after work every night for about a month. From 9 PM to usually 1 AM.
