Old 10-11-2004, 10:23 AM   #1
71400lb
71400lb
Where is the windshield washer pump?
My windshield washer pump was disconnected when I got the truck...so I reattached the lines, but it still doesn't work. Can somebody tell me where the pump or show me a pic of what it looks like?
I haven't checked the fuse yet...does it have its own fuse or would other accessories be out as well if that fuse was bad?
Thanks,
71 Cheyenne C/20 Long Bed 2x4
400/400
3.73/open
duals
71400lb is offline   Reply With Quote
Old 10-11-2004, 10:42 AM   #2
JimKshortstep4x4
Smile
The washer pump is mounted to the wiper motor under the dash just above the gas pedal.
The washer pump is not fused separately. If the wipers are working it should have power. If it does not activate when you press the button, then the pump could be bad, bad switch or a wiring problem.
Jim
Old 10-11-2004, 10:44 AM   #3
Sweet72
Sweet72's Avatar
Windshield washer pump is part of the wiper motor, located on the inner side of the firewall under the dash. It's a rubber diaphram type and probably is dry rotted. Fuse is same as wiper. I think you can buy a rebuild kit for the pump. I guess Jim was a little quicker at the draw than me
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 10-11-2004, 11:00 AM   #4
71400lb
71400lb
Thanks!
Thanks guys, GEEZ I would have NEVER found it! I would have torn apart the entire cowl looking for it!
Can I just buy a compatible pump or they don't make them anymore?
Is it a difficult job to swap out the pump?
Thanks,
Rick
Old 10-11-2004, 11:01 AM   #5
JimKshortstep4x4
Smile
Sweet 72,
Good point on the washer seal being dry. Usually they are too bad to make work. I went through 10 washer pumps looking for a good one with no success. I finally bought a new one!
Jim
Old 10-11-2004, 11:28 AM   #6
Sweet72
Sweet72's Avatar
I bought the pump at Napa in 1996 and at that time they offered a pump rebuild kit. Don't even waste your time going to Autoxone or any other discount parts house. Hopefully they still sell these parts, let us know please.
Old 10-11-2004, 12:04 PM   #7
Stryker67
Stryker67's Avatar
I gave up on my pump after getting frustrated to no end with it. I just bought one of those $8 aftermarket pumps, and a momentary on toggle switch. I by-passed the old pump entirely....
[FONT=Georgia]
If nothing else, we can all serve as a bad example.
We don't know what we don't know.
The world needs ditch-diggers too.
Stryker67 is offline   Reply With Quote
Old 10-11-2004, 12:50 PM   #8
Kas68c10
Kas68c10's Avatar
I needed and couldn't find one also. I bought the electrical after market pump and wired it into the switch so I didn't need the toggle !
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
