Old 10-11-2004, 02:15 PM   #1
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Tilt column - Differece between van and truck?
I have a chance to buy a Tilt column that the seller claims is correct for my '72. I know that there is a difference between van and truck columns specific to overall length but I am not sure what that is.
What do I look for to confirm that this column is infact an original truck column and not a modified van column? Are all 67-72 truck columns the same? I think that the 67/68's have the shaft as part of the steering box. Finally, if this is the real deal, what is a fair dollar to pay?
Dual quad is offline   Reply With Quote
Old 10-11-2004, 02:27 PM   #2
71swb4x4
71swb4x4's Avatar
The shaft coming out of the end of the column is the main difference. On a truck tilt it's about 2 inches and on a van tilt it's about 6 inches.
The Neutral safety switch is also in a different location.
All 67-72 truck tilts are the same.
It seems that truck tilits have been right around the $200 mark for one that is nice but unrestored.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-11-2004, 02:30 PM   #3
71swb4x4
71swb4x4's Avatar
You can see the difference in shafts with these Ebay auctions.
Van tilt
http://cgi.ebay.com/ebaymotors/ws/eB...category=42609
Truck tilt
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old 10-11-2004, 03:51 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Does this help?
http://67-72chevytrucks.com/vboard/s...483#post888483
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-11-2004, 05:39 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Also, as far as 67/68 trucks go, there was no tilt.
Old 10-12-2004, 01:23 AM   #6
HeavyD
HeavyD's Avatar
Geez..I just shelled out 250 dollars for what is now obviously a van tilt. The seller claimed it was an original out of a 72 Sierra Grande..I guess not. Oh well, I will throw this thing in my beater truck and keep looking
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is online now   Reply With Quote
Old 10-12-2004, 07:53 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My so dissapointed? I mean, get it installed and likely no one will ever know it's not a "correct" tilt for your truck. They look original when installed, unless, like was said, you check the length of the shaft sticking out in the engine compartment. But 999 out of 1000 guys couldn't tell by looking that it's not original.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-12-2004, 12:17 PM   #8
Dual quad
Dual quad's Avatar
Excellent feedback guys, exactly what I needed to know. Thanks
Old 10-12-2004, 12:59 PM   #9
Dual quad
Dual quad's Avatar
Oh yeah, is the correct connector straight or curved?
Old 10-12-2004, 05:19 PM   #10
neonlarry
neonlarry's Avatar
Curved, the vans are straight. GM sells adaptors.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 10-12-2004, 07:03 PM   #11
Longhorn Man
early vans had the hose shoe connector. I think 75 or so was when they chainged.
Old 10-26-2004, 09:49 PM   #12
kxmotox247
kxmotox247's Avatar
Does anyone have the part number on the GM adaptor? Or what do you ask for if you want one?
kxmotox247 is offline   Reply With Quote
Old 10-26-2004, 10:07 PM   #13
HeavyD
HeavyD's Avatar
I too would like the part # if anyone has it..dealing with our GM dealer without numbers is hopeless.
Old 10-26-2004, 11:04 PM   #14
neonlarry
neonlarry's Avatar
Gm Part # 1894851
Old 10-27-2004, 12:49 AM   #15
Swbman
IMO, it doesn't matter if its a VAN Tilt or not and their low price and easiness to find in salvage yards makes them a win win thing and as mentioned above once installed the average joe wouldn't be know the difference,and as far as the flat connector harness that comes on the van tilts,I just cut a horseshoe shape connecting harness from a bad truck column and use wire connectors and hide the connectors under the little metal wiring harness cover that attaches to the column shaft.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 10-27-2004, 04:03 AM   #16
HeavyD
HeavyD's Avatar
Swbman: I have a horseshoe plug and was wondering about cutting the rectangle plug off the tilt and replacing it with the horseshoe. The problem is that the van tilt has 8 wires coming out, and the wire colors do not all match the horseshoe plug colors. Also, on the "big" horseshoe plug end there are 8 wires, but on the "small" horseshoe end (composed of 2 smaller plugs) there is only 7 wires. Am I missing one? What wire color goes to what? If it is possible to splice in the horseshoe in place of the rectangle plug I will do it...if is too much hassle I will just buy an adapter.
Thanks.
Old 10-27-2004, 12:08 PM   #17
ScottH
ScottH's Avatar
Not to highjack the thread, but since it's on the same subject, what is the best way to handle to extra length on the van column shaft?
Thanks.
ScottH is offline   Reply With Quote
Old 10-27-2004, 12:12 PM   #18
Tx Firefighter
you collapse the intermediate shaft between the column and box until it fits properly.
Old 10-27-2004, 12:16 PM   #19
StingRay
StingRay's Avatar
The collpsable shaft between the column and the box can be banged in a couple of inches and is good to go. It is retained at it's stock length by plastic pins that will shear when you collapse it. The only real draw back to the van column is if you ever end up in a bad collision the wheel will end up a couple of inches closer to you that it would with a stock truck column as you are using up the some of the built on collpse room built in by GM. Personally it wouldn't worry me.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 11-01-2004, 04:52 PM   #20
Stepsides 4Ever
Stepsides Are Bedder
Stepsides 4Ever's Avatar
Straight or horseshoe? No adapter is necessary.
This is not as hard as it looks. You can take a small jeweler's screwdriver or small flat strip of steel (like a flat hair pin) and insert it between the wire terminal and the horseshoe/straight plastic connector to release the wire terminal. Pull the wire & terminal out the back side of the connector. You will have to do this if you ever need to replace a broken turn signal cam anyway, to get the wires through the column cover. It's a simple matter to re-wire to the stock connector, be it straight or curved, and match whatever wiring is there. If needed, go to the boneyard and tear one apart and you will see how easy this can be accomplished!
Stepsides 4Ever is offline   Reply With Quote
