Old 10-14-2004, 02:53 PM   #1
Cliff
installing a 1989 350 in my 72
hey everone, i purchased a 1989 chevrolet van with a TBI 350 that just had the upper end re-built. I am planning on doing a swap this weekend. My truck is set up for a 4-barrel and I know what is involved in changing over the intake. My question is, how hard would it be to convert my truck to run with the TBI ? What modifications have to be made ? Are there any advantages if i ran the 350 as TBI as opposed to using my 4-barrel. Which is better? Is one more powerful, better fuel economey ? thanks everyone. I need to be decided by saturday !
also what rear-end gears are in the 89 van ? it's supposed to be heavy duty... would the gears be better than the stock gears in my 72 half ton ?
Cliff
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor.
Cliff is offline   Reply With Quote
Old 10-14-2004, 02:56 PM   #2
FormerMember
Well, the TBI will probably net you better fuel economy.
A conversion harness and a computer re-program will probably make you life much simpler.
I don't believe you can bolt a 4 barrel onto the TBI manifold. You'll need an adapter or a new manifold. Also, the 1989 heads are different, so to use your carb manifold, you'll have to wallow out the holes. The heads use an straight bolt location, which is a wee bit different.
FormerMember is offline   Reply With Quote
