Old 10-15-2004, 04:34 PM   #1
rockguy
Wheel stud question
When I changed my c-30 Dual rear wheels from the old split rims to newer rims the wheel studs are not long enough to accept the wheel spacer. I have not had any luck locally to find a longer stud anyone have any ideas where I can get them. They are 1/2 25.
Thanks Steve
69 c-30 dually flat bed & dump ( best truck ive owned
87 chevy dually
97 1500 classic
89 wellcraft
rockguy is offline   Reply With Quote
Old 10-15-2004, 05:44 PM   #2
rodnok1
rodnok1's Avatar
Napa has a book with all the specs for wheel studs in it and cross references. If you have knurl size, shoulder length and overall length and thread (1/2 -20??) I can try and get you a number from their book. Send me a PM if interested.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 10-16-2004, 02:30 PM   #3
Gator70
Gator70's Avatar
Depending on the length you need, Moroso has extra long wheel studs for race applications. You just need the knurl diamater to make sure you get a proper fit. Dorman/Motormite also shows a wide variety. Wagner has a good buyers guide. Also be careful of the shoulder length to make sure that it doesnt interfere. If this is on your 69 c30 I can look them up and get the specs if you havent already.
Good luck hope this helps.
http://www.motormitedormancatalog.com/
http://www.moroso.com/
1970 GMC K15 - Canadian built
2nd Owner truck 68k miles
2014 Denali 1500 6.2L
Gator70 is offline   Reply With Quote
