Old 10-19-2004, 08:55 AM   #1
RShaips
will these wheels fit my 86 4x4 ?
I can get a great deal on 4 - 15 x 10 6 lug wheels and 33" tires that came off of a 96 Toyota Tacoma. Are these the same bolt pattern as my Chevy ? I know that the old Toyotas used to have the same pattern as the Chevys but do not know about the newer trucks. Thanks for the help
RShaips is offline   Reply With Quote
Old 10-19-2004, 01:34 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Yes, they are both 6 on 5.5bc, just verify the backspacing because anything more than 4" will rub your tierod ends.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-19-2004, 03:54 PM   #3
Destructo
If you have stock springs your most likely going to rub on the front fenders, if it was a 15x8" wheel you might could get away with it.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 10-19-2004, 04:10 PM   #4
RShaips
Stock springs for now, but I am going to raise it with a 4" lift, I thought they would fit, I will just have to make sure that center opening on the wheels will fit over the front hub. Thanks for the help
Old 10-19-2004, 04:35 PM   #5
Destructo
Toyotas don't use a hub centric wheel I don't think, so they should fit fine, and with a 4" lift they will clear fine. But with stock 1/2 ton front springs I can almost gurantee they will rub. I'm running 15x8s with 33x12.5" tires on CUCV military front springs and I can clear the 33s, but it gets close if the front suspension flexes.
Old 10-19-2004, 04:56 PM   #6
RockHQ
ROCKET POWER!
RockHQ's Avatar
Besides bolt pattern you must consider stud diameter too. If the toyota wheels have a large stud hole (14mm for example) you might have a hard time finding lug nuts that will not bottom out on the rotor before gripping the wheel, and conversely the mounting holes might be too small to fit your chevys studs (7/16" IIRC).
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 10-19-2004, 05:08 PM   #7
Jonboy
Slots go on anything!
15x10 is going to be an aftermarket wheel anyhow, so you should have no problems.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-19-2004, 08:59 PM   #8
Destructo
if its aftermarket it will fit for sure.I never seen a 15x10 yota wheel, so your probably good to go.
