Old 10-20-2004, 12:17 AM   #1
69GMCCamper
Question What to look at?
I'm going to look at a 69 4X4 Blazer this weekend. I was wondering what kind of things I should look at that has trouble in these Blazers. Spots that rust out, suspension problems, top troubles, etc. Thanks in advance.
69GMCCamper is offline   Reply With Quote
Old 10-20-2004, 12:52 AM   #2
stivic
Hey good to see another B.C. member. these blazers rust everywhere the rocker boxes,front window frame and window supports/kick panels.the best thing to do is check out members progres pics and threads.That will give you a good idea what to look for. Good luck
stivic is offline   Reply With Quote
Old 10-20-2004, 11:55 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Check the top for splitting too. If it is a double wall top, they tend to split.
'69 may have either the Dana 20 or NP205 t-case, depending on the transmission. Both are good t-cases, but the NP205 is stronger. Check the ball joints, tie rod ends, etc. It should have drum brakes upfront, but they are often swapped out with '71 or '72 disc front axles.
Check the frame around the steering box, especially if it has bigger tires on it.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 10-20-2004, 01:00 PM   #4
71swb4x4
71swb4x4's Avatar
Here is a similar thread.
http://67-72chevytrucks.com/vboard/s...ghlight=blazer
Hope it helps and good luck!!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
