Life is Good !
carpet install questions
I got all my carpet and weather stripping togeather for the burb
![]() Anyway I layed in the carpet last night, and since there is no prepunched holes for the seat bolts, and the highbeam switch or the gas pedle. I was wondering how everyone cut these holes with out messing up the carpet. I have never had to deal with carpet before so any ideas would be great. ![]() ![]() P.S. WES http://www.classicheartbeat.com/ I figured out the trim deal on the barn doors :p There was some kind of trim on the door that did not look anyware close to the stock style ![]() ![]()
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
Just make sure you got the carpet where you want it and then go under and use a awl (icepick) and punch up through hole . Then take a tube (piece of pipe, oid socket etc.) the size you need for bolt and sharpen end. Use this to cut out hole. Makes a nice round hole with no fraying.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
1969 Custom 30 wrecker
Another way is to install the bolts before you put the carpet down. Then just feel for them and cut a slit or X on top of the bolt.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I just installed the carpet in our Garden Truck project and used jhow66 method mostly. I only used his method to locate the seat though. Once I located the seat, then I used speed bolts to bolt the seat down. The threads come to a point and are self aligning. Just ran them through the carpet and no holes were necessary. We cary them for $.75 each. WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
You can also put in a later model gas pedal(no floor attachment) to keep from cutting that hole. Thats the most visible and largest besides the high beam switch and that should have a rubber gromet to make it look neat.
Oh and a gasket punch works good for the holes.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI Last edited by neonlarry; 10-20-2004 at 07:49 PM. |
Life is Good !
Thanks for the info guys !
![]() Join Date: Feb 2000
Are you going to put down any type of insulation under the carpet or just have it on the metal floor?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#8 | |
Life is Good !
![]() ![]() Anyway yes I am putting down some insulation ! ![]()
#9 | |
Life is Good !
Where did you order your carpet ? I need one for my 'burb.
Also, did you install the OEM headliner ? Need to resolve this, too. Any pics ? Thanks Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry 71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster 70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges |
#11 | |
Life is Good !
Got all my carpet and weather stripping from WES at http://www.classicheartbeat.com/ Fast Friendly service from that guy there ![]() ![]() As for the head liner I am probally going to get the head liner done at and apostery (sp) <----- "I know it is wrong" Shop. I have only seen one place with a headliner and I thing it cost something ![]() ![]() As for the pictures, well mabe next week of the carpet and what not, but as for the head liner, I think that will be an x-mas gift for the wife ![]()
