Old 06-24-2002, 07:51 PM   #1
Jefe
Jefe's Avatar
Exclamation Slight miss in motor..please help.
I have a 68 Chevy, with a mild 350 in it. Just had heads machined and put together 1.94 & 1.50 stainless. New springs, new lifters, new aluminum intake, new points and condenser, plugs cap/rotor, new wires. When I am driving ( not all the time) but sometimes it will like "hiccup" it will actually miss real quik and return to normal, engine runs at about 190 degrees. I am thinking that it is a slight carb problem..(quadrajet). Checked the dwell and timing, both are perfect. New fuel pump too. Other than the miss every no and again, it runs really strong and smooth. Any ideas, anybody? Thanks again!
Jefe is offline   Reply With Quote
Old 06-24-2002, 07:57 PM   #2
COBALT
COBALT's Avatar
What happens under hard acceleration, like from a dead stop to WOT?
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 06-24-2002, 07:58 PM   #3
Baradium
Binder Rep
Baradium's Avatar
wiring maybe?
Baradium is offline   Reply With Quote
Old 06-24-2002, 08:01 PM   #4
Jefe
Jefe's Avatar
The engine harness and light harness under the hood is all brand new same with spark plug wires. Under hard excelleration it seems to run fine, but misses every once and awhile.
Old 06-24-2002, 08:14 PM   #5
jhow66
jhow66's Avatar
miss
Loose coil wires?--loose wire on coil?--loose ground wire inside dist.?--loose wire on ignition switch? Does it feel like you are turning the switch on and off?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-24-2002, 08:25 PM   #6
Gordo
Smile
Even one spark plug going bad/fouling would do that.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-24-2002, 08:29 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Lightbulb
is the coil new ? i had one that when the coil heated up it died. replaced it and no more problems . 2 things that keep the engine running- gas and fire.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
