Old 10-27-2004, 10:20 AM   #1
cheyenne10
cheyenne10's Avatar
brake fluids?
Standard brake fluid I believe is DOT 3 rated. (the kind that eats paint). Does anyone have any experience with the synthetic DOT 5 version? The Dot 5 stuff I just saw was purple colored and also listed a higher boiling point. After painting master cyl. up and the going thru install and bleeding I got some paint peeling problems with DOT 3.
Next time I want it to look good when done.
Bob
cheyenne10 is offline   Reply With Quote
Old 10-27-2004, 10:27 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Lots of old car guys use Dot 5 synthetic becasue it's non-hydroscopic.
It lends itself well to cars that set around for long periods of time.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-27-2004, 11:05 AM   #3
rickspickuppart
we use Dot 5 in most of the restos we do mainly because it is more resistant to eating off paint (But over time it will destroy paint unless it is cleaned off), it is alot more difficult to bleed out because it a bit thicker and also it doesn't mix w/ dot3 because it is silicone based.
Also be ready to spend some money if you go w/ dot 5 the stuff is waaaay overpriced and other than the "not eating paint" property of DOT 5 you won't notice any big advantages from it (it's designed mainly for road racing because it is more resistant to expanding/boiling under extreme heat conditions).
rickspickuppart is offline   Reply With Quote
Old 10-27-2004, 11:13 AM   #4
Dean
Dean's Avatar
I use the silicon brake fluid in the old Vettes. It doesn't absorb the moisture like the old stuff. It will not mix as they said above. you need to bleed all the old stuff out first. And it is more expensive.
Dean is offline   Reply With Quote
Old 10-27-2004, 11:40 AM   #5
Budweis
Geared for Collision
Budweis's Avatar
i use it for same reason dean mentioned bout not absorbing moisture, i wasnt even aware it doesnt eat paint. make sure you evacuate lines well of old stuff before using. i took my lines off on last one and blew them out with air to get the old stuff out. im going to use on my truck project but replacing all the lines on it so wont have to worry bout it this time.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB
1970 C/K20 3/4 Ton
1996 Collectors Edition Corvette
1977 Corvette Coupe
Budweis is offline   Reply With Quote
Old 10-27-2004, 11:57 AM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
i considered the dot 5 stuff - i understood that the system must be 110% free of dot 3 before you install it. I also understood that it absorbes air rather than water. I went with the ford (ack, I know) dot 3 because its rated like 100deg higher than reg dot 3 & its totally compatable & if I ever need to add fluid on the road, its easily availible. Check into the FERD stuff.
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-27-2004, 02:13 PM   #7
neonlarry
neonlarry's Avatar
I use dot 4 fluid higher boiling point than dot 3 not as hydroscopic either. As mentioned above dot 5 tends to aerate rather easily which leads to a spongy pedal feel.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
