Old 10-30-2004, 06:55 PM   #1
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
Spicer Hubs Question?
I took the allen head bolts out of them today and was looking inside them to see if i could see anything. Because one of them is loose and makes a little noise when i lock it in. I went to put them back on and when turn the knob to point at the word free and put them on the hub wont spin the way its apost to it spin counterclockwise away from the word lock. Not toward the word lock if anybody has any advice it would be greatly appreciated thanks in advance.
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
Old 10-30-2004, 11:02 PM   #2
nu2-72
I am guessing that this is for your 78 3/4?
Do you have the big hubs or the small ones?
Big hubs are 3/8" bolts around the outside and small are like a 10 x 32 inside the round face.
I ask because I just installed a set of Warn Premiums on an 87 3/4 with small hubs. They say that the lockouts are supposed to wobble a little. They do not fit as tightly as the large hubs. If the lockouts are tight, it would be because we had the axles all the way out and did not assemble the lock nuts and spacer correctly. I do not know how far you went into yours. The first (inner) lock nut has a small pin that sticks out. It must be rotated exactly for the spacer with tab to line up with the shaft keyway and for a spacer hole to line up over the pin. Then the outer/second jam nut. The lockouts are then installed in the free position. Line up the inside notches with the hub face correctly and install. Jack up the front end completely and turn a tire or rotor. The driveshaft does not turn in free. Turn the lockout and spin again. The driveshaft will rotate when locked.
Does this help?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-31-2004, 12:02 AM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Take the hub face back off and trun the knob to lock. Then reinstall the hub. That should make it right...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-31-2004, 11:01 AM   #4
784X4GUY
784X4GUY's Avatar
Thanks guys; Last night I went out there and tried again. This time i got them to where they would go to lock and free. Now there isnt any weird things that can happen right if it goes to lock and free then there right correct? Is there anyway they can reverse and the lock position be free and vice versa. I thank yall for the help so far.
Old 10-31-2004, 01:56 PM   #5
nu2-72
They should stop at free and lock. Jack up the truck and check the driveshaft rotation to be sure. They have to be right but this will be another learning experience. Try it out and be sure in your mind. Peace of mind is worth alot.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 10-31-2004, 06:39 PM   #6
784X4GUY
784X4GUY's Avatar
Yeah nu2-72 you were right bout that. I jacked it up and checked and i locked both hubs and the driveshaft spun. I was wondering why dont the driveshaft spin if you just have one hub locked. But thanks for the help man.
Old 10-31-2004, 09:17 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If you only lock one hub then the differential will only allow the other shaft to turn vice the driveshaft.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
