11-13-2004, 11:01 PM | #1 |
Final engine assembly adhesive
Putting together my crate motor - it came with a tube of GM Assembly Adhesive which I assume should be used to seal the intake manifold. It says on the back it's used for sealing engine oil joints only. Is this correct? I've read here before that orange adhesive should be used but can I use this included adhesive?
Here's a pic: |
11-13-2004, 11:48 PM | #2 |
blood type; Retumbo
I would say judging from the size of tube & description it is meant to be used for the end rails of intake to block area. (silicone)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-14-2004, 08:34 AM | #3 |
Watch out for your cornhole !
He is correct.
