Old 11-27-2004, 03:48 AM   #1
super72bb
Need a rebuilt power steering box
Need a rebuilt power steering gearbox for a 1972 1/2 ton 2wd. If anyone can point me in the right direction.
Curt
1972 CHEYENNE SUPER SWB BLACK. 402 BB, TH400, AIR, TILT, TACH, BUCKETS, CRUISE, AM/FM, 8 TRACK.
My build thread:
http://67-72chevytrucks.com/vboard/s...=1#post7120181
super72bb is offline   Reply With Quote
Old 11-27-2004, 05:40 AM   #2
GSFMECH
On the road
GSFMECH's Avatar
You can get them at most auto parts stores, I recently bought one for my 98 Z71 from a bumper to bumper auto parts store. A bit pricey but worked well. I think mine was about $230 or so but a older 2wd would be cheaper. They are easy to rebuild yourself though if none of the hard parts are bad,all the seals/ bearings are available from any parts stores. I did my 72 a few months ago but mine had leaks mainly. After adjusting it out on the bench it was good and tight and no leaks. hope this helps,
Mike
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 11-27-2004, 08:32 AM   #3
bigunde
Rusty Rockerfeller
I got this from www.advanceautoparts.com website,seems like decent prices,but i think i would just stick a kit in mine too if the gears were ok.
Cardone 275004
Steering Gear: Reman.; Manual Steering
Lifetime Limited Warranty Ships in 1 day
Weight: 17 lbs. $248.88
$220.00 core
Cardone 277501
Steering Gear: Reman.; Power Steering
Weight: 32.6 lbs. $187.77
$75.00 core
Lares 1074
Remanufactured; Power Steering
Lifetime Replacement Warranty Ships in 1 day
Weight: 31.5 lbs. $149.99
$50.00 core
Lares 855
Remanufactured; Input Shaft Has A Flat Side; Manual Steering
1 Year Replacement Warranty Ships in 1 day
Weight: 14 lbs. $212.19
$75.00 core
bigunde is offline   Reply With Quote
Old 11-27-2004, 12:01 PM   #4
bean
steering box
I just bought one for my 69 thru LMC. I was very pleased with the parts and the price was good.
bean is offline   Reply With Quote
