12-02-2004, 03:37 AM | #1 |
Garage Queen Material
Intermittent Wiper problems
my truck came with this option, but it has never worked.
what can i do to fix it? the wipers work at the only 2 full speeds, but the pulse ones dont |
12-02-2004, 11:22 AM | #2 |
The little module that is right under the column (behind that plate) is prob. bad.
The electronics inside can't take much heat and they fry at a pretty fast rate. I have bought two from GM in the last 10 years and I am not gonna fix it again. |
12-02-2004, 01:03 PM | #3 |
Shadetree Mechanic
Take the control module apart.
Mine quit or was intermittent and I took the control module apart thats at the base of the steering wheel and found broken/cracked solder joints on the PC board, touched it up with a soldering iron and has been working fine since then.
Dave M. (Hacksaw) 86 C10 Scottsdale LWB, 4.3L, Edelbrock 1904, K&N, 700R4, 3.08 Auburn Performance 89 GMC S-15 Extended Cab 4x4, 4.3L, FI 98 K1500 Xcab, 5.7L, 3.43 Gov-Lok |
12-03-2004, 04:07 AM | #4 |
That's not a bad idea............thanks!
12-03-2004, 07:20 AM | #5 |
Mine does the exact same thing, it definetely is the control module.
