Hey Everyone.. Its been awhile since I've been on but I'm starting to work on my 68 again but the problem is I have so much to do where do I get started? I know everyone here has had that overwhelming feeling. This is what I have goin for me so far.. Motor and tranny are in.. no acessories on just the motor and trans. no rad. either I have my no limit gauges in and they are all wired but the rest of the interior is gutted. I need to take the fuel tank out so I can drop my fuel cell in under the bed.. other than that I still need front disc brakes and redo the suspension.. WHERE DO I START? Someone, anyone, everyone help me out here.. what makes the most sense where to start my project up again?
I prefer working from the ground up. Especially if space is limited at least the frame/truck is mobile. I'd say do the brakes and suspension, then fuel cell, back to the engine compartment and then interior.
'68 Short Step LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc |
Lovin' Life in Miss.!
You around Sacramento? I like workin on these trucks.... Could offer you a hand.
The truck... you hear that? No really, you did hear that?!!! |
#4 | |
![]() Join Date: Aug 2003
The best place to start, or in your case Re-start, is in the suspension, then proceed to the drivetrain. If your okay with the way the suspension is for now, then go ahead with all "mechanical" aspects so you can, at least, get it back and forth dependably from where ever it might need to go.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
68lss1 has the right idea. Once you get the rolling chassis, you can roll it in and out of your work area, if you need to clean or work on something else. I would definitely get a rolling chassis. I got all of the brakes and suspension done, dropped the motor and tranny.
After that, the radiator support seemed to be the next best thing...this allows you to get the mechanicals done without leaning over fenders. I did the gas tank and fuel and brake lines along the frame next. Then cab, then exhaust. That should keep you busy a while.
69 SWB LT1/4L60E www.classicplace.com |
Thanks alot you guys... I think I have my route all planned out. This is my first project that I am taking seriously and I really want to do everything the way I want, right the first time. I'll post pics this weekend on what I have to work with. Probably gonna start with suspension and brakes.. I do have a question tho.. I have a 6 lug drum set up all the way around and I want to convert over to 5 lug with drop spindles in the front. I know it will be time consuming but how hard is it to get all the spindles set up from a cut spring..ghetto previous owner.. to a dropped spindle disc brake setup... I want to lower the truck about 4" in the front .. or somewhere close to that.. and 6" in the back.. I have leaf springs in the back and cut coils in the front.. Anyone got any suggestions? Thanks again everyone!!!! By the way chickenwing I'm from the Bay Area... Pacifica
It's been my experience that when it comes to fixing up vehicles, the question inevitably evolves from "Where do I start?" to. "Where do I stop?"
#8 | |
ouch. Bit far. Hopefully we will have a NorCal board meet one day.
