Old 12-16-2004, 08:18 PM   #1
chipotledude05
Strategery
Arrow 10 bold question
I have a pair of '88 10 bolts out of a suburban. Judging from the size of the discs and drums, i think they may be 3/4 ton. Not sure, but that's not my question. Since the 10 bolt has a 30 spline center section, could you replace the stock axle shafts with a set of Warn 30 spline shafts and have an axle stronger than a 44?
chipotledude05 is offline   Reply With Quote
Old 12-16-2004, 09:15 PM   #2
smokkey1
Land Beast
there 1/2 ton not 3/4 ton. are you going to do any wheeling with those axles??? you could replace the shafts with warns. but the 30 spline shafts aren't much stronger than the 28 spline shafts. the rear axle is still going to be weak the carrier is a pos and won't hold up to any offroading with larger than 32" tires. you won't have too much problems with the front axle if you don't lock it. I've been wheeling on my 10 bolt front for little over an year now with out problems and that's on my suburban with 36" swampers but I'm easy on the skinny peddle and it's open up front.
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
Old 12-17-2004, 08:25 AM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If you have a rear 10 bolt it's half ton. A 3/4 ton would have had a 14 bolt rear.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 12-21-2004, 12:20 PM   #4
784X4GUY
Did someone say MUD?
784X4GUY's Avatar
I agree with Jim my 78K20 has a D44 front and a 14Bolt FF in the rear.
Im in the market guys...so keep ya eyes peeled
Mini trucks are for guys who cant get it up!
784X4GUY is offline   Reply With Quote
