Old 03-08-2005, 11:28 PM   #1
chip46wis
Unhappy Custom grill
HELP! I have the Jegs catalog from last summer? on the cover is a 68-72 bright yellow chev with a phantom grill that covers from side to side over the headlights also--it completly fills the shell area----Ive called jegs 2 different times and they have no idea of where that grill or truck came from----Anybody know of a company that makes this grill?- I just spent 2 hours on the net and no luck HELP-please
chip46wis is offline   Reply With Quote
Old 03-08-2005, 11:29 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Carriage Works I think is one company and Trenz is another.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-08-2005, 11:58 PM   #3
Peregrine
Peregrine's Avatar
Might be spelled trendz, I can't remember. There was a pretty long thread on it though/
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 03-09-2005, 03:00 AM   #4
bigcdawg99
They featured this truck in Truckin' around six months ago and I believe it is a Trenz grille. I called Trenz directly and they said the grill will fit Chevy and GMC. I'm hopefull since I want one for my GMC. I don't know what they run but Trenz said you could give the part number to any of there venders and they could order it. I ofcourse can't find the part number right now but if you call Trenz directly they will give it to you.
71 GMC Shortbed Fleetside (under construction)
"I like guns. You got a gun, you don't have to work out."
Chris Rock
bigcdawg99 is offline   Reply With Quote
Old 03-09-2005, 11:05 AM   #5
GreyHoundSteve
I did alot of research on doing this mod to my 67 and its alot of work and alot of $. The grill is a "full phantom" and its made by Trenz and Cariage Works and is for the 69-72 model. It sells for about $375-$425 depending on where you buy it. The tricky part about this mod is that the fenders will have to be trimed to fir the grill. I was 100% sure i wanted to do this mod until i found out how much everything would cost and then my body guy wasnt briming with confadence about cutting the fenders to make it fit right so i decided against it. Also keep in mind that in NO state is this grill legal and since my truck evolved into a daily i didnt want to hassle with the cops all the time.
Definately the coolest grill ive seen though.
GreyHoundSteve is offline   Reply With Quote
Old 03-09-2005, 12:54 PM   #6
shifty
Questionable
shifty's Avatar
I really like what that guy did with the front bumper in that yellow truck. Very slick.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
