Old 03-21-2005, 09:59 PM   #1
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
65 with bucket seats
Hey Ya'll, I just installed a set of 69-70 pickup bucket seats with a later model console in my 65. What do you all think of the way it looks? I'll say one thing they are a whole lot more comfortable than the bench seat. They also were not a bolt in. Had to do a slight amount of fab work but nothing big. Kevin
65StreetCruiser is offline   Reply With Quote
Old 03-21-2005, 10:39 PM   #2
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Talking
Looks cool what is the console from?
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 03-22-2005, 08:54 AM   #3
65StreetCruiser
It Is What It Is
PJ STYLES, The console is from a 73-80's Chevy Pickup, looks like the 69-72 console except that it has cup holders ( for your favorite beverage ) instead of slots for the seat belts.
Old 03-26-2005, 12:44 AM   #4
BrianJordan
Iron Thunder
BrianJordan's Avatar
it look's like a70's blazer console.
BrianJordan is offline   Reply With Quote
Old 07-28-2005, 12:52 AM   #5
65_Chevy
Looks good I think I might do that myself. btw where did u get your steering colum out of. Was it hard to swap I have a 74 chevy thought about using that if it will work
65_Chevy is offline   Reply With Quote
Old 07-28-2005, 01:00 AM   #6
squizzleboy
I am going to install some silverado buckets im my 63. Did you weld up a frame to bolt the seats to?
squizzleboy is offline   Reply With Quote
Old 07-28-2005, 05:09 AM   #7
cajunbowtie
I like!!!!
cajunbowtie is offline   Reply With Quote
Old 07-28-2005, 07:41 AM   #8
65StreetCruiser
It Is What It Is
65 Chevy, The tilt steering column is out of a 71-72 Chevy pickup. Not hard to swap, almost a bolt-in. Just had to buy a wiring adapter to go between the column and truck wiring connectors. A Chevy van column up to the mid 80's as well as some mid 60's Buick, Olds, and Pontiac columns will work as well. The trouble with using a 74 column is that, (1) it has the key switch on the column, Hence 2 ignition switches(2) If I remember right where it comes out of the dash it is bigger around than the original column.
squizzleboy, All that I had to do to make these seats fit the truck was to use some 3//4 square tubing underneath the front seat mounts. The late model Silverado buckets I think would be almost a bolt in because the floor pans in these old trucks are relatively flat.
