08-11-2005, 06:28 PM | #1 |
fuel filler hoses
Any pics of fuel filler hoses and door on late model step side beds. Iv'e got a late model stepside bed on my 69 with a blazer poly tank and need some ideas THANKS.
08-11-2005, 09:35 PM | #2 |
Its a Truck Thing......
Im using a cool cap in the wheel well, plus marine fuel hose, my only issue is the poly tank uses a 1 1/4 neck, atleast mine does, no no no nobody around here sells that size hose for a good price. plus the cool cap uses 1 1/2 hose. I have a adapter from a hose shop that connects them both and should last awhile. I can get you pics if you like...
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
08-13-2005, 02:15 PM | #3 |
Yes please.
08-13-2005, 04:48 PM | #4 |
Life, Be In It.....
Put together by another member
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
08-13-2005, 08:47 PM | #5 |
Sorry,
I will get the pics in the morning.... Smitty
08-13-2005, 10:02 PM | #6 |
you have a late model bed? then use it's built in gas door and filler neck and run the hose to the rear where the tank is.
08-15-2005, 06:24 PM | #7 |
I don't want to run a hose that long the fuel tank is way in the back and the fuel door is toward the cab on a late model bed. Plus it wont work too well with the c-notch.
08-15-2005, 06:39 PM | #8 |
that isn't so much hose. its expensive to buy that much at $10 a foot though. you could run it up to the inner frame rail, all the way back to the tank. that should flow nicely down to the tank.
08-15-2005, 10:24 PM | #9 |
hose
Sorry it took so long, here are the hoses Im using, this stuff will last forever.....pretty cheap too. Picked it up from the hose store locally.
Smitty
08-17-2005, 09:08 PM | #10 |
Did you run that hose to stock location or inside the bed?
08-17-2005, 09:59 PM | #11 |
mine went to the wheel well....Ill take a pic tomorrow.
Smitty
